Hi all,
I can get these manufactured in small quantities for $US2.50 each.
If there is any interest I will go ahead and order some.
Postage should be just a couple of dollars as they can fit in a standard envelope.
cheers
Tony
Are you referring to the flat flexible cable that goes to the print head?
Haven't looked inside a 9x in a long time; only printer cable I remember. Isn't the FFC permanently attached to the print head? If we're referring to the same cable, apparently not permanently attached.
Irrespective of the above, can your source fabricate the FFC suitable for the HP Thinkjet? Including the ink cartridge end of the cable with the "bumps"?
There are scads of thermal inkjet printers ("bubble-jets") which use the same ink cartridge as the Thinkjet. I have several calculators (not HP) which use the same cartridge; hence the cartridge mating end of the cable match the Thinkjet. However, the PCB end may be shaped/spaced different. And the "routing" shape on the cartridge end may be different. i.e. straight-in to the cartridge connection area or "L" shaped, etc.
If your source can make a Thinkjet cable, I'd think there would be a significant customer base for a small number of cables for other products also. But they all would have the same print-head end where the ink cartridge seats.
Attached is a picture of the cable end I'm referring to from a Thinkjet manual.
** EDIT **:
The reason I ask: a lot of us know the bubblejet type printers often have ink leakage on the FFC cartridge mating surface. So the connection gets damaged as the ink "eats off" the conductive surface on the FFC. Hence, missing dots when you print (or none at all).
Often wondered if a thin layer of a dielectric grease might help protect the cartridge/FFC mating surface.
(12-07-2023 11:56 AM)Duane Hess Wrote: [ -> ]Are you referring to the flat flexible cable that goes to the print head?
Sorry, long day, my error. I had printers on my mind and meant the card reader ribbon connector.
I changed the subject.
cheers
Tony
This strikes me as one of those "you'll never get this chance again" kind of offers. On the off chance I'll ever be dumb enough to refurbish another topcat, count me in for two cables.
Wow, I didn't know these had become scarce. I used to order them from Mouser and Digikey in the early 2000's.
Tony, put me down for 8 of them. Thanks.
-J
Hi Tony - could I order four please? Thank you! Andrew
Hi Tony,
i never had a failure with this cable but i will take 4 of them.
Ralf
Hello Tony,
I will take four (4) please.
Thank you!
Sylvain
Hi Tony,
Very nice, thank you. I would like to order 4.
Kind regards,
Kees.
Hi all,
I placed the order for the ribbon cables.
They FedEx'd the package to me and added taxes, cost will be $US2.75 each
Postage should be ok from here in an envelope so should be cheap.
cheers
Tony
(12-09-2023 01:48 AM)teenix Wrote: [ -> ]Postage should be ok from here in an envelope so should be cheap.
Be sure and check postage first before collecting payment, particularly overseas mail. The US postal service has really been picky of late about what can go in an ordinary envelope, requiring the more expensive tyvec sort.
PM sent.
Hi all,
I received the new Topcat printer ribbon cables from the manufacturer today. They ended up being $US2.60 each. I don't intend making a profit, hopefully just to recoup the cost.
Image shows a damaged one and the new.
Now the problem is getting them around. I was thinking of putting them in a Xmas card and send that way to save on the ridiculous postage for such an item. I can send money in a card, so I don't see what the difference is.
If that fails, I may be stuck with them, or I can send a bulk package to US where someone, if they had the time, could redistribute locally. Either way, I'll have some left, so I'll add one to any 97 CPU boards I make.
cheers
Tony
Hi Tony,
I missed the initial request for these but if there's any left or you can't send them all I will take a couple.
I'll pickup sometime :-)
Thanks, Darren
(12-22-2023 01:24 AM)teenix Wrote: [ -> ]Hi all,
cheers
Tony
Hi Tony
I missed also the initial request and would take two.
Tanks, Hans-Peter
(12-22-2023 04:59 AM)dmh Wrote: [ -> ]Hi Tony,
Thanks, Darren
cheers
Tony
Hi Tony,
I missed the initial request but put me down for 6,
Thanks,
-Tom
(12-22-2023 01:24 AM)teenix Wrote: [ -> ]I received the new Topcat printer ribbon cables from the manufacturer today. They ended up being $US2.60 each. I don't intend making a profit, hopefully just to recoup the cost.
Looks good!
Just let me know the price including postage and where to send it - like a PayPal address.
Thanks,
-J
