11-27-2023, 10:06 AM
since i cannot post in the articles forum i will post here some additional hints.
There were many questions about repairing the paper advance rollers.
1. How to cut silicone tube?
Since i mentioned that cutting doesn't have to be absolutely exact, i will describe my method:
I have a mini drill from proxxon, which is high precision. I take a milling cutter and clamp it reverse into the drill chuck, so that the shaft is below.
The diameter of the cutter is appropriate to the tubing. Then i cut the tube with a sharp cutter (I use hardened steel blades)
2.Which tubing should be used?
I take standard silicone fuel tube for aeromodellers engine, which you can by from tower hobbies or dubro, amazon, ebay...
The outer diameter is a bit over 7mm, the inner 3.2mm. I think it is a 7/3 silicone tube.
Other types may work either. The outer diameter when mouted should not exeed 8.5mm
Ralf
[attachment=12950]
[attachment=12951]
Ralf
[attachment=12950]
[attachment=12951]
