10-09-2023, 01:35 PM
Hi all,
I have now proven and tested my thesis that the Raspberry Pico (see other threads about it) can be used to emulate - not only ROM modules and RAM - but also other hardware.
My goals with this was to emulate the Wand (82153A) since I wanted an easy way to enter programs into the calculator from a PC without going through HP-IL, cassette drives, or creating modules.
The card reader or the Wand are easy to use and a great way to enter programs into the calculator.
As described in other threads, the Pico attaches to the HP41 just as a module and can listen to and send signals on the different buses.
What differs the Pico from other MLDL or Clonix devices, is that we can also e.g. toggle the FI signal, which is used to signal from external hardware (ie cardreader or Wand) into the calculator.
With the program I have used in the Pico, I can e.g.:
To plug any module into the Pico, a ROM-file is needed (same format as modules are shared online).
The module is then "plugged" into the calculator with the following command:
This flashes (in ~1 second) the ZENROM module into page 10 (0xA) - upper page in port 2, that's it ... !
And all pages from 0x4 to 0xF are available for ROM's (but I have not implemented any bankswitching yet).
But as mentioned, my goal was to emulate the Wand, and by flashing the Wand ROM into the Pico, and emulating the buffer and pulling the FI-line, I can now "scan" any barcode into the calculator!
To realize this, I have added a separate flash-page (page 16 (0x10) - can contain up to 4K of data) in the Pico to contain barcode data (for any HP82153A compatible barcode), and to "scan" a program I use the following steps, in this case I try the large "CASTLE" program (https://www.hpmuseum.org/software/41castle.htm):
(Note that I have modified and added a "binary" printer ('/e') to the HP41UC tools, which just saves the barcode in a binary format, and that the program can be in any hp41uc tool compatible format.)
Then I just type 'w' in the terminal to start the Wand emulation - "scanning" the barcode data - moving it into the emulated Wand buffer and start playing with the ISA and FI to get the calculator to read the data from the wand into RAM.
A short video showing when the 160 lines of "barcodes" are scanned into the HP41 can be seen here: Scanning 160 barcodes
Note that the calculator is powered off and is started by the Pico - just as if the Wand button was pressed!
Yes, I know, it is not optimal - the HP gets very slow before being "packed" - and also the ping-sound after every scan is a bit annoying (my plan is to update the Wand-ROM to remove the "ok" beep, that will also make it a bit faster) ... but how long would it take to manually scan 160 barcodes with a real Wand - or transfer the original Focal program into the calculator?
Next step would be to replace the terminal with an application where I can select which file or any barcode to download into the Pico - just point and click!
And with clever programming - a new module could be made, which directly talks to the PC or a filesystem on the Pico to directly inject any data into RAM or XMem, using the options that the Pico offers with access to the PC.
So yes - I think I have achieved at least my goal and proved what can be done with the Pico - knowing that there are some other interesting projects going on with similar emulations of hardware!
Cheers,
- Emulate modules and QRAM
Modules can be flashed into the Pico and be "plugged" into the calculator as any normal module.
Any page can also be marked as QRAM, so normal MLDL functionality can be used - Drive ISA
Not only used for addresses or instruction, but also pull ISA to turn the calculator on if needed (as when pressing the button on the Wand) - Drive FI
This is used by e.g. the Wand to indicate that the Wand is active, or when the Wand data-buffer contains data for the calculator to read.
$ ../flash.sh ZENROM.ROM 10
# Convert the text-file to raw format using the hp41uc tool (can be skipped if RAW is available):
$ ~/tools/hp41uc/hp41uc /n /t=castle.txt /r
# Convert the RAW HP41 program to binary barcode data:
$ ~/tools/hp41uc/hp41uc /r=castle /e
# Flash the "barcode" data into the Pico flash memory (page 16)
$ ../flash.sh castle.bin 16
Loading into Flash: [==============================] 100%
Verifying Flash: [==============================] 100%
OK
#Thats it!
Cheers,
