09-16-2023, 07:47 PM
From thread Companion program for Joe Horn’s continued fractions article.
Python code, translated for HP Prime (if micro-Python available, that should work too)
Once minimum denominator are picked, program pick minimum numerator too.
Code assumed number are *exact* fractions, not float.
Cas> frac_between(18/10,19/10) --> 9/5
Cas> frac_between(18/10,18/10) --> 9/5
Cas> frac_between(18/10,17/10) --> 7/4
Cas> frac_between(18/10,16/10) --> 5/3
Cas> frac_between(18/10,15/10) --> 3/2
Cas> frac_between(18/10,14/10) --> 3/2
Cas> frac_between(999999999977/10^12,999999999978/10^12) --> 43478260869/43478260870
d_convergent(a,b, d1,d2)
LOCAL ia, ib;
ia, ib := floor(a), floor(b);
IF ia == a THEN RETURN d2, d1+(ia-1)*d2 END;
IF ia != ib THEN RETURN d2, d1+ia*d2 END;
d_convergent(1/(b-ib), 1/(a-ia), d2, d1+ia*d2);
frac_between(a,b)
LOCAL d, d2;
IF a>b THEN a,b := b,a END;
d, d2 := d_convergent(a,b, 1,0);
REPEAT d += d2 UNTIL (a*d) <= floor(b*d);
RETURN ceiling(a*d)/d;
