08-23-2023, 08:40 PM
An excerpt from E D N magazine (international edition), Calculator performs 2's-complement math, 1990/10/11, page 221, Peter Kielbasiewicz.
"The calculator programs in Listing 1―HP-28 binary-arithmetic routines make up for the Hewlett-Packard HP-28 calculator's lack of 2's-complement binary-conversion routines."
"The first program negates a number in 2's-complement form."
"The second program converts numbers from real to binary and binary to real."
BEST!
SlideRule
BNEG ;negate a number with
;respect to 2's complement
<< -> a ;store entered number into local variable
<< IF ->STR NUM 35 SAME ;if number begins with '#'
THEN a NOT 1 + ;then make 2's complement
ELSE a NEG ;else simply negate
END
BCONV ;convert from real to binary with
<< 2 RCWS 1 - ^ -> b ;b = max pos number for act wordsize
<< IF a ->STR NUM 35 SAME ;if number begins with '#'
THEN a B->R ;then convert it to real
IF DUP b >= ; if a >= b
THEN b 2 * - ; then make negative result
END ; endif
ELSE IF a 0 >= ;else if a >= 0
THEN IF a b >= ; then if a >= b
THEN "Size Err" ; then ERROR (a > max)
ELSE "a NEG R->B ; else make positive binary
END ; endif
ELSE IF a b NEG < ; else if a < -b
THEN "Size Err" ; then ERROR (a < min)
ELSE "a NEG R->B NOT 1 + ; else make negative binary
END ; endif
END ; endif
END ;endif
BEST!
SlideRule
