LOCAL
POSI,SOLCNT,UNICNT,
COLS,DU,DD,ALLSOLS,UNISOLS;
LOCAL LASTP;
EXPORT QUEENS(DIMENSION)
LOCAL N,START;
START:=TICKS;
N:=DIMENSION;
//PRINT(N+" Queens");
SOLCNT:=0;
UNICNT:=0;
POSI:=MAKELIST(0,X,1,N,1);
COLS:=MAKELIST(0,X,1,N,1);
DU:=MAKELIST(0,X,1,2*N-1,1);
DD:=MAKELIST(0,X,1,2*N-1,1);
ALLSOLS:={};
UNISOLS:={};
TRY(N,1);
SOLCNT:=SOLCNT*2;
//PRINT(SOLCNT+" solutions, "+UNICNT+" unique");
//PRINT((TICKS-START)/1000+" seconds")
TEXTOUT_P("FIN",0,40);
WAIT(0)
LOCAL TRY(N,ROW)
LOCAL M,COL,DUI,DDI,DUP,DUP2,I;
IF ROW>2 THEN
M:=N
ELSE
IF ROW=1 THEN
M:=IP((N+1)/2)
ELSE
IF N MOD 2=1 AND POSI(1)=(N+1)/2 THEN
M:=IP(N/2)
ELSE
M:=N
END
END
FOR COL FROM 1 TO M DO
DUI:=ROW-COL+N;
DDI:=ROW+COL-1;
IF COLS(COL)=0 AND DU(DUI)=0 AND DD(DDI)=0 THEN
POSI(ROW):=COL;
IF ROW=N THEN
SOLCNT:=SOLCNT+1;
IF POS(ALLSOLS,POSI)=0 THEN
ALLSOLS:=CONCAT(ALLSOLS,{POSI});
DUP:=POSI;
DUP2:=MIRR(N,DUP);
ALLSOLS:=CONCAT(ALLSOLS,{DUP2});
FOR I FROM 1 TO 3 DO
DUP:=TURN(N,DUP);
ALLSOLS:=CONCAT(ALLSOLS,{DUP});
DUP2:=MIRR(N,DUP);
UNISOLS:=CONCAT(UNISOLS,{POSI});
UNICNT:=UNICNT+1;
SHOW(N,POSI)
END
ELSE
COLS(COL):=1; DU(DUI):=1; DD(DDI):=1;
TRY(N,ROW+1);
COLS(COL):=0; DU(DUI):=0; DD(DDI):=0
END
END
END
LOCAL MIRR(N,P)
LOCAL R,M;
M:=P;
FOR R FROM 1 TO N DO
M(R):=N+1-P(R)
RETURN M;
LOCAL TURN(N,P)
LOCAL R,T;
T:=P;
T(P(R)):=N+1-R
RETURN T;
LOCAL SHOW(N,P)
LOCAL D,I,T,E,OX,OY,M;
LOCAL GRAY,WHITE,BLACK,CLR;
D:=IP(237/N);
OY:=IP((239-N*D)/2);
OX:=319-N*D-OY;
GRAY:=RGB(224,224,224);
WHITE:=RGB(255,255,255);
BLACK:=RGB(0,0,0);
M:=IP(D/6);
IF UNICNT=1 THEN
RECT();
E:=N*D;
FOR I FROM 0 TO N DO
T:=I*D;
LINE_P(OX,T+OY,E+OX,T+OY);
LINE_P(T+OX,OY,T+OX,E+OY)
FOR I FROM 1 TO N DO
FOR E FROM 1 TO N DO
IF (E+I) MOD 2 = 0 THEN
RECT_P((E-1)*D+1+OX,(N-I)*D+1+OY,E*D-1+OX,(N-I+1)*D-1+OY,GRAY)
IF P(I)=E THEN
RECT_P((E-1)*D+M+OX,(N-I)*D+M+OY,E*D-M+OX,(N-I+1)*D-M+OY,WHITE,BLACK)
END
END
END
ELSE
IF P(I)≠LASTP(I) THEN
RECT_P((LASTP(I)-1)*D+M+OX,(N-I)*D+M+OY,LASTP(I)*D-M+OX,(N-I+1)*D-M+OY,IFTE((LASTP(I)+I) MOD 2=0,GRAY,WHITE));
RECT_P((P(I)-1)*D+M+OX,(N-I)*D+M+OY,P(I)*D-M+OX,(N-I+1)*D-M+OY,WHITE,BLACK)
END
END
LASTP:=P;
TEXTOUT_P(UNICNT,0,0,3,BLACK,100,WHITE);
TEXTOUT_P(SOLCNT,0,20,3,BLACK,100,WHITE)
The program runs, on my HP Prime G2 with current firmware, fine for up to 11x11 queens, but fails with out of memory for 12x12 and above. For 12x12, there are a few hundred different solutions, and for each 8 variants are stored (original, turned 3 times, and each mirrored). That should be much less than 1000 elements, each a 12-element array of real numbers. I guess that should easily fit in main memory.
