The Emu48 is too big on my coworker's 44 inch, 2560 x 1600 flat screen monitor. He has to close the task bar to see the bottom row of the Emu48 keyboard. Is there a way to decrease the size of the Emu48? The KML script that he's using is Jemac's Gx.
(08-10-2023 12:23 AM)MNH Wrote: [ -> ]The Emu48 is too big on my coworker's 44 inch, 2560 x 1600 flat screen monitor. He has to close the task bar to see the bottom row of the Emu48 keyboard. Is there a way to decrease the size of the Emu48? The KML script that he's using is Jemac's Gx.
There is a "Scale" parameter available for the global section of the KML-file.
Example: Scale 2 3
It should be described in the KML documentation.
Also look into changing the scaling in Windows. At that low of a resolution on a 44" screen, scaling should only be set to 100%, not 125% or 150%.
Changing to a different KML could work too -- some of the ones I designed work fine at only 600 or 800 vertical pixels. Only my largest needs around 1200 pixels at 100%.
