07-17-2023, 05:16 PM
Euler Polynomials for HP-17B
Memory Map
N: Order (Integer)
N0:Last N (Integer)
N9: N!
X: X argument (Floating point)
X9: X-0.5
E(): Bernoulli number array (Floating point)
E0: Bernoulli polynomial Bern(N,X) (Floating point)
I, J, K, M: Loop control variables (Integer)
Usage
1) Press RUN key.
2) The program displays the prompt "N? ".
3) Enter N and press the END LINE key.
4) The program displays the prompt "X? ".
5) Enter X and press the END LINE key.
6) The program displays N, X, and the value of the Euler polynomial.
7) Press the [f][+] keys and go to step 2.
Example
Examples of B(N,X) are:
B(8,2.5) = 56.66015625
B(6,2.5) = 21.796875
B(4,2.5) = 10.3125
Listing
The above code checks if the value of N you enter is the same one you entered the last time. If so, the code skips calling the subroutine EULR since it already has the values of the Euler numbers from the last round of calculations.
Memory Map
N: Order (Integer)
N0:Last N (Integer)
N9: N!
X9: X-0.5
Usage
1) Press RUN key.
Example
B(4,2.5) = 10.3125
Listing
Line Step
10 REM EULER POLYNOMIAL
20 DESTROY ALL
30 N0=0
40 INPUT "N? ";N
50 INPUT X? ";X
60 IF N=N0 THEN GOTO 100
70 DIM E(N)
80 CALL EULR(E(),N)
90 N0=N
100 E0=0
110 N9=FACT(N)
120 X9=X-0.5
130 FOR K=0 TO N
140 E0=E0+N9/FACT(K)/FACT(N-K)/2^K*E(K)*X9^(N-K)
150 NEXT K
160 DISP "E(";N;",";X;"=";E0
170 PAUSE
180 GOTO 40
190 END
200 SUB EULR(E(),N)
210 E(0)=1
220 FOR M=1 TO INT(N/2)
230 S=1
240 FOR K=1 TO M-1
250 R=1
260 FOR J=2 TO 2* K
270 R=R*(2*(M-K)+J)/J
280 NEXT J
290 S=S+R*E(2*K)
300 NEXT K
310 E(2*M) = -S
320 NEXT M
330 END SUB
