07-16-2023, 02:58 PM
07-16-2023, 04:28 PM
(07-16-2023 02:58 PM)n3mmr Wrote: [ -> ]Is there some source of reliable info on the HW design of the HP Prime calcs, g1 as well as g2?imho your are in the right place, just use "search"
07-16-2023, 04:29 PM
This is what I can recall at the moment, there might be other developments I'm not aware of or that I forgot about.
Regarding the HP Prime G1:
- There is some basic BOM information on TI-Planet's wiki (https://wiki.tiplanet.org/HP_Prime/Hardware)
- There is a QEMU fork accurate enough that it can boot* the original firmware (https://github.com/opcod3/qemuPrime/tree/s3c2416)
- There's my long-abandoned bare-metal third-party firmware (https://github.com/boricj/ripem)
Regarding the HP Prime G2:
- Someone ported Linux to it (https://www.zephray.me/post/hp_prime_g2_linux/)
- That same person also wrote a bit about the internals (https://www.zephray.me/post/hp_prime_g2_...gineering/)
- Another person ported some version of Windows to it (https://www.imbushuo.net/blog/archives/725)
*my recollection is that at some point early, pre-release firmware versions predating the unlock-style wizard did boot, it might've improved since then
Edit: if it can boot on a physical calculator or if it can run the official firmware then I consider it to contain reliable info about HW design, even if it's in source code format.
07-17-2023, 08:34 AM
Thank you, mr Boric!
