08-25-2014, 04:21 PM
There appears to be a problem with ->HMS in Home, if the argument is between -1 and 0, e.g.,
->HMS(-0.1) returns 0 degrees 06 minutes 0 seconds,
same as ->HMS(0.1).
Even entering -0 degrees 6 minutes on the command line returns the positive value of 0 degrees 6 minutes.
However, HMS->(-0 degrees 6 minutes 0 seconds) returns -0.1, so that is fine.
Thanks for looking into that!
same as ->HMS(0.1).
