05-11-2023, 01:18 AM
HP Prime diagnostic menu
To enter the "EA656 DIAGNOSTIC" Screen Menu:
press [F] + [C] + [O] keys while press and release pin reset to the back where 'O' is the capital letter 'O' and not the thinner number '0'.
inside the diag: [ESC] back, [O] stop test.
1 L/B Test - Screen and Touch Test:
1 Main LCD (display test)
2 LCM (touch test)
P PRESET (cycling)
2 M/B
1 Main LCD
2 Key
3 Adapter IN
4 Battery
5 Tablet
6 RTC
7 Led
8 USB host test
P PRESET (cycling)
3 F/A
1 MEM
2 LCD
3 Keyboard
4 TABLET
5 RTC
6 LED
7 USB host test
P PRESET (cycling)
4 FLS Utility
1 Boot&Bios CheckSum
2 N-Flash INFO
3 Format Disk C (resets to factory-new condition)
5 Evaluation
1 TABLET
2 RAM
3 CHK BAD FLASH
4 CPU/CAL
5 LCD
6 KEY
7 RTC
8 USB
9 BATTERY
A BKLED
B LED
C TEMPERATURE
D HUMIDITY
6 Reliability
1 ITEM
2 LOOP SET:100000
3 RECORD
4 ERROR
5 CLEAR ALL DATA
6 ERR HALT/GO:GO
7 START
8 CONTINUE
7 USB TEST
1 Prime to Prime
2 Dongle Test
3 HID Device
4 PRESET
8 TP FW Refresh
9 RESET exit test mode and reboot
A Version Info
B DEEP MODE
C POWER OFF MODE (turn off power)
Simple soft reset (recovers keyboard control, restores most of RAM to the
state it was in at the last power-down, losing changes made in the current session:
press [On] + [Symbol] keys or using the Reset hole at the back of the unit.
Quick minor factory reset (clears most of memory, but maintains calculator name,
color theme, language):
press [Apps] + [Esc] keys and holding them while pressing the [On] key.
2 LCM (touch test)
P PRESET (cycling)
2 M/B
1 Main LCD
2 Key
3 Adapter IN
4 Battery
5 Tablet
6 RTC
7 Led
8 USB host test
P PRESET (cycling)
3 F/A
1 MEM
2 LCD
3 Keyboard
4 TABLET
5 RTC
6 LED
7 USB host test
P PRESET (cycling)
4 FLS Utility
2 N-Flash INFO
5 Evaluation
1 TABLET
2 RAM
3 CHK BAD FLASH
4 CPU/CAL
5 LCD
6 KEY
7 RTC
8 USB
9 BATTERY
A BKLED
B LED
C TEMPERATURE
D HUMIDITY
6 Reliability
1 ITEM
2 LOOP SET:100000
3 RECORD
4 ERROR
5 CLEAR ALL DATA
6 ERR HALT/GO:GO
7 START
8 CONTINUE
7 USB TEST
1 Prime to Prime
2 Dongle Test
3 HID Device
4 PRESET
8 TP FW Refresh
A Version Info
B DEEP MODE
