04-25-2023, 03:21 PM
Since RPN and FOCAL with it stack is efficient for iterated functions, here a posting of the iterated function of aN=(an + b/an) / 2 which result will be SQRT(b).
Other way to represent this is f(x,y)=(x+y/x,y). Then f(f(f(..(a0,b))))=(sqrt(b),b).
The start value a0 can be anything (result will have the negativ sign if the start value a0<0).
Nothing really new:
- no register used in comparison to the programm available in page 11 in https://literature.hpcalc.org/community/...ram-de.pdf )
- start value can be defined (will be defined as b if a0=0)
- no calculation done if b=0
Nothing really new:
; SQRT as iterated function, "möbius transform like" = only + * or /
; Execution/Inputs
; a0 ENTER b XEQ ALPHA SQRT ALPHA or
; b XEQ ALPHA SQRT ALPHA
; ... b number which should be squared
; ... a0 is a start value for the iteration
; ... if a0 is negativ, the result will be negativ value of the square root
; Outputs
; results in stack X: sqrt(b)
; Modules used
; None
; use Register none
; stack effect: all overwritten (X Y Z LASTX)
; create raw file with "rpncomp --raw-output SQRT.TXT", upload
; in V41 emulator and store into virtual drive with "ilper"
; .. hp41uc https://sourceforge.net/projects/hp41uc/ or
; rpncomp https://github.com/hth313/Calypsi-tool-chains
; .. V41 https://hp.giesselink.com/v41.htm
; .. ilper https://hp.giesselink.com/hpil.htm
; under CC BY SA CreativeCommons 4.0
; floppy @ https://www.hpmuseum.org/forum/
; idea taken from here
; https://en.wikipedia.org/wiki/Methods_of_computing_square_roots#Heron's_method
; change log
; date 2023 04 24 creation
; date 2023 04 25 testing..
; comments
; aN=(an + b/an) / 2
; .. a number to be squared.. it mean aN (N-> infinite) = sqrt(a)
LBL "SQRT"
; X Y Z T
; b a0
X<=0? ; in case b <= 0 dont do anything
RTN ; ... just go out
X<>Y ; a0 b
X=0? ; in case a = 0 set a to b
XEQ 00
X<>Y ; b a0
STO Z ; b a0 b
X<>Y ; a0 b b
LBL 01
RCL Z ; b an XX b
X<>Y ; an b XX b
STO Z ; an b an b
/ ; b/an an b b
LASTX ; an b/an an b
+ ; (an+b/an) an b b
2
/ ; (an+b/an)/2=aN an b b
X#Y?
GOTO 01
RTN
LBL 00 ; X Y Z T
RDN ; b
ENTER ; b a(=b) 0
RTN
END
