Hi Guys, for several years, I am seeking a scientific calculator with a big screen and keyboard and never found one, so I decide to make a retro one. the simple way is using a calculator ASIC and connecting it to LEDs and a mechanical keypad. Unfortunately, there are too few chips with LED output directly, so I should make a LCD to LED converter first. After doing the first test, it runs OK. It's not an emulator but a "real" machine. Here is the prototype of the calculator with the original PCB. The next step is to integrate all the parts into a whole PCB, and add mechanical keys, wish you like it.
Quote:With the replicas of the chip used in EL-506P, the first „clones” was built in similar housing as used in EL-506H, at various factories in Hong Kong, Taiwan and China. Later, with similar appearance and same model number, a simple programmable calculators based on a genuine Sharp chip — which was made for Sanyo — completed.
(05-13-2023 03:03 PM)EdS2 Wrote: [ -> ]Aha - looks like quite a few manufacturers used that chip (Edit: but these are programmable, which is confusing me):
It seems that the chip LI3301A is used for OEM manufacturers only. All SHARP calculators that use this chip are clones (fake). I bought many used calculators with this chip that have different suffixes, including 506P/506H/514.
Also, I heard that this chip has a clone one which was made by a Vietnam company.
