04-02-2023, 04:22 PM
I feel this observation is worth a discussion, from over on the latest Pi Day offering:
I find myself caught in a superposition of states: a lack of surprise that sometimes division will round upwards, and a great surprise that this rounding happens so very rarely in this experiment.
Checking a few of the examples, it seems that division on this 12 digit calculation will round upwards if the 13th digit would be 5 or greater. Is it obvious as to why this should happen so rarely - am I missing something?
Why these particular divisors, and why should divisors come and go as we traverse the table? Is there pattern here which I'm not seeing?
(03-29-2023 01:16 AM)Valentin Albillo Wrote: [ -> ]Indeed IP(T/(K*K)) and T DIV (K*K), which would appear at first sight to be equivalent, do really differ at times (though very rarely and for large values of T, it seems,) when the former's rounding does not match the latter's truncation.
A trivial program I wrote (relatively) quickly finds all mismatches for various very large integer T and for K from 2 to IP(√T) (i.e. ~ one million possible cases for the first eight values of T listed):T # Mismatches K
As you can see, for T = 999,999,999,999 there are 31 different instances (in about a million) where IP(T/(K*K)) differs from T DIV (K*K), for K ranging from 1 to IP(√T). The instances begin at K = 2 (249,999,999,999 vs. 250,000,000,000, respectively) and end at K = 500,000 (3 vs. 4, respectively).
999,999,999,999 31 instances 2, 5, 8, 16, 20, ...
999,999,999,998 19 instances 2, 3, 8, 20, 25, ...
999,999,999,997 12 instances 3, 8, 25, 80, ...
999,999,999,996 3 instances 3, 3125, 31250, ...
999,999,999,995 3 instances 2, 3, 254
999,999,999,994 1 instance 254
999,999,999,993 1 instance 254
999,999,999,992 0 instances -
99,999,999,999 0 instances -
Doing the same with T = 999,999,999,998, there's just 19 instances reported instead of 31, and with T = 999,999,999,997 just 12. By the time T equals 999,999,999,995, a mere 3 faulty instances remain (namely for K = 2, 3 and 254), then 999,999,999,994 and 999,999,999,993 have just the one mismatch (in a million !) and for 999,999,999,992 and below there seems to be none.
Also, as expected, running this small program for input values with less than 12 digits, say T = 99,999,999,999 instead, i.e. 1E11 - 1, no instances of mismatches appear at all, and probably the same happens for all smaller T.
