all,
About a week has elapsed since I posted this
\(\pi\) Day 2023 Special challenge, thank you very much to those few of you who contributed your valuable solutions and/or comments, namely
2old2randr,
J-F Garnier, vaklaff and
John Keith, really much appreciated.
On the one hand, it's a pity that it failed to attract the attention of other people usually interested in my productions but that's life. On the other hand, this time I got
RPL (and even
Sys RPL ! ) solutions, which were conspicuously absent from past challenges.
Now's the time for my detailed
sleuthing process and resulting
original solutions, plus
additional comments:
My sleuthing process
First of all, if naively taking at face value the problem's statement, you'd might be tempted to just program a simple loop from
1 to
N, compute the factorization for each number and tally up the ones which have repeated factors. This is as simple as it gets but for large
N (say 1 million) it's grossly
inefficient and here we're most interested in raw
speed.
What to do ? Search in references or the
Internet for a better algorithm, that's what, in particular one which is better than
O(N), as any such loop will take
ages for large
N, even if nothing were done inside the loop. We need something which is at least
O(√N), thus transforming a
1,000,000-cycle loop into a
1,000-cycle one.
To search for that, we notice that asking for numbers whose factorization has
no repeated prime factors is tantamount to asking for numbers who
aren't divisible by any square other than 1, which are usually called
square-free integers, and a quick
Google search for the term reveals many relevant links, among them one at
Wolfram Research's MathWorld, where we find a formula with the required order (i.e. the upper limit of the summation goes up to
√N,) equivalent to this one:
which also appears in text form as
a(n) = Sum_{k = 1..floor(sqrt(n))} mu(k)*floor(n/k^2) at
OEIS A013928 Number of (positive) squarefree numbers < n, and many other sites and documents. The simple proof of this formula can be obtained using the
inclusion-exclusion principle.
As for the
Möbius function, it's a very important
number-theoretical function which is easily computed in various ways, like this simple
HP-71B user-defined function
FNM (which should be placed at the end of any program using it):
1 DEF FNM(N) @ IF N=1 THEN FNM=1 @ END ELSE F=1
2 D=PRIM(N) @ IF NOT D THEN FNM=(-1)^F ELSE IF MOD(N,D*D) THEN F=F+1 @ N=N/D @ GOTO 2
>FOR N=96673 TO 96686 @ FNM(N); @ NEXT N @@ ► 1 1 0 0 0 0 0 0 1 1 1 0 -1 -1
>S=0 @ FOR N=1 TO 1109 @ S=S+FNM(N) @ NEXT N @ S ► -15 { Mertens(1109) }
but the important thing here is that we only need
√N evaluations of it instead of
N, which makes all the difference in the world.
My original solutions
Yes,
solutions, plural, as I created
two of them, optimized for different cases. My
first solution is optimized for speed, regardless of memory use, and uses the
S(n) formula above, but instead of computing each
individual value for the
Möbius function inside the loop, it does compute
all √N values en masse before starting the summation loop, which can be done without factoring, multiplications or divisions by using a trivial
sieve procedure similar to the well-known ancient
Sieve of Eratosthenes algorithm used to find all prime numbers up to a limit.
The sieve procedure used here runs fast, ultimately winning over for large
N, and all needed values of
Möbius(n) are left stored in an array to be later used inside the summation loop.
First solution: speed
This little
4-line,
217-byte HP-71B program implements the procedure, first sieving and storing in
INTEGER array
M all
√N Möbius values needed, then computing the summation and outputting results and timings:
(uses Math and JPC ROMs)
1 DESTROY ALL @ INPUT T @ SETTIME 0 @ N=SQR(T) @ INTEGER M(N) @ MAT M=CON @ P=2 @ WHILE P<=N
2 S=P*P @ FOR K=S TO N STEP S @ M(K)=0 @ NEXT K @ FOR K=P TO N STEP P @ M(K)=-M(K) @ NEXT K
3 P=FPRIM(P+1) @ END WHILE @ S=T @ FOR K=2 TO N @ S=S+M(K)*(T DIV (K*K)) @ NEXT K
4 DISP USING "2(3DC3DC3DC3D,2X),2(Z.8D,X),5DZ.2D";T,S,SQR(6*T/S),ABS(PI-RES),TIME
N Count \(\pi\) approx |Error| go71b Emu71/Win Physical
@128x @976x HP-71B
12,345 7,503 3.14198205 0.00038939 0.10" 0.01" 13"
100,000 60,794 3.14155933 0.00003333 0.28" 0.04" 36"
567,890 345,237 3.14158684 0.00000582 0.69" 0.09" 1' 28"
1,000,000 607,926 3.14159550 0.00000285 0.93" 0.12" 1' 59"
10,000,000 6,079,291 3.14158749 0.00000516 3.03" 0.40" 6' 28"
25,000,000 15,198,180 3.14159240 0.00000025 4.87" 0.64" 10' 23"
33,000,000 20,061,593 3.14159276 0.00000011 5.61" 0.74" 11' 58"
1E8 60,792,694 3.14159307 0.00000042 9.93" 1.30" 21' 11"
1E9 607,927,124 3.14159260 0.00000006 32.45" 4.26" 69' 14"
The caveat is, storing all
Möbius values in
INTEGER array
M does require large amounts of memory if
N is huge, e.g.:
- For N = 1E8, the program uses ~ 30,055 bytes of RAM (M has 10,000 elements, 30,000 bytes)
- For N = 1E9, the program uses ~ 94,927 bytes of RAM (M has 31,623 elements, 94,869 bytes)
Larger values of
N are problematic, e.g.
N =
1E10 would require in excess of
300 Kb of
RAM, at the very limit of what the
HP-71B can manage, which leads us to my
second solution, where I'll turn from computing all
Möbius values
en masse to computing them
individually, thus avoiding the large memory requirements, albeit at the cost of speed.
Second solution: memory
This even smaller
3-line,
178-byte HP-71B program uses in-lined
Möbius function code (as oposed to an
user-defined function) for speed, and needs only ~
63 bytes of
RAM to run no matter the size of
N, all the way to a
trillion (1012) - 1, i.e.
999,999,999,999, which is the largest integer the
HP-71B can represent:
(uses JPC ROM)
1 DESTROY ALL @ INPUT T @ SETTIME 0 @ U=-1 @ S=T @ FOR K=2 TO SQR(T) @ N=K @ F=1
2 D=PRIM(N) @ IF NOT D THEN S=S+U^F*IP(T/(K*K)) ELSE IF MOD(N,D*D) THEN F=F+1 @ N=N/D @ GOTO 2
3 NEXT K @ DISP USING "2(3DC3DC3DC3D,2X),2(Z.8D,X),5DZ.2D";T,S,SQR(6*T/S),ABS(PI-RES),TIME
@128x @976x HP-71B
12,345 7,503 3.14198205 0.00038939 0.09" 0.01" 12"
100,000 60,794 3.14155933 0.00003333 0.26" 0.03" 33"
567,890 345,237 3.14158684 0.00000582 0.67" 0.09" 1' 26"
1,000,000 607,926 3.14159550 0.00000285 0.91" 0.12" 1' 56"
10,000,000 6,079,291 3.14158749 0.00000516 3.15" 0.41" 6' 43"
25,000,000 15,198,180 3.14159240 0.00000025 5.15" 0.68" 10' 59"
33,000,000 20,061,593 3.14159276 0.00000011 5.98" 0.78" 12' 45"
1E8 60,792,694 3.14159307 0.00000042 10.81" 1.42" 23' 4"
1E9 607,927,124 3.14159260 0.00000006 36.93" 4.84" 78' 47"
1E10 6,079,270,942 3.14159267 0.00000002 2' 8" 16.82" 4h 33'
1E11 60,792,710,280 3.14159265 0.00000000* 7' 37" 59.95" 16h 15'
1E12-1 607,927,102,274 3.14159265 0.00000000* 28' 9" 3' 41" 60h 2'
* the 12-digit values are 3.14159265115, 0.00000000244 and 3.14159265250, 0.00000000109, respectively.
Thus, although this second solution can achieve the maximum possible integer range
1 ..
1012 - 1 with no memory problems and even seems to be a little faster for
N up to
1 million, this is only because the
HP-71B hardware and
BASIC language are optimized for fast
mathematical operations performed entirely in
assembler without user loops or branching, which are pretty slow and thus slow down the sieving procedure.
This is why a
matrix inversion (
MAT INV) or a
Fast Fourier Transform (
FOUR) are performed at speeds competing with much faster
CPUs, while an empty
FOR-NEXT construct does only
~100 loops/sec. on a physical
HP-71B. Even so, the second solution will get increasingly slower than the first one for large
N.
Additional Comments
● In the
very distant past
(2004), I posted the pair of threads:
where I pitted the
HP-71B vs. the
HP49G+, executing various quite hard computations, and the resulting times showed that the
HP49G+ was usually about
4.6x to
6.4x faster than the
HP-71B, so any timings must take this into account in order to ascertain the relative performance of the various solutions running on different hardware.
● You may be wondering why I selected
N =
33,000,000 as a test case. It's an innocuous number in and of itself but I found it while reading this truly
excellent book eons ago:
The Mathematical Experience by Phillip J. Davis and Reuben Hersh
(464 pages, ISBN-10: 9780395929681)
where they say:
"A more refined piece of natural scientific research into prime Numbers was reported in a paper by I. J. Good and R. F. Churchhouse in 1967 [...]"
and they elaborate in
page 367, I quote:
"To check their probabilistic reasoning, Good and Churchhouse did some numerical work. [...] In a separate calculation, they found that the total number of zeros of μ(n) [VA: the Möbius function] for n between 0 and 33,000,000 is 12,938,407.
The "expected number" is 33.000.000*(1 -6/\(\pi\)2). which works out to 12,938.405.6. They call this "an astonishingly close fit, better than we deserved." A nonrigorous argument has predicted a mathematical result to 8 place accuracy. In physics or chemistry. experimental agreement with theory to 8 place accuracy would be regarded as a very strong confirmation of the theory. Here, also, it is impossible to believe that such agreement is accidental. The principle by which the calculation was made must be right. "
I was sure it took them considerable time to get the tally for
33,000,000 using some 1967-era computer and wanted to know how long it would take a 1984-era handheld
HP-71B to get the result, which is less than
12 min. for a physical machine and less than a
second for a modern emulation
(Emu71/Win).
Both timings would be reduced at least an order of magnitude if rewritten in
assembler and run in the same hardware (perhaps
J-F Garnier would obligue and create a
MAT M=MOB matrix statement which would fill up array
M with the results of the sieving procedure implemented in
BASIC in my first solution ...
By the way, the aforementioned 1967 paper by I. J. Good and R. F. Churchhouse is:
The Riemann Hypothesis and Pseudo-random Features of the Möbius Sequence
where among other very interesting things, they say:
"Thus the Möbius sequence contains arbitrarily long runs of zeros, but these long runs presumably occur extremely rarely."
I showed
above such a run of zeros from
N =
96675 to
96680,
six consecutive zeros in all. It would make for an interesting challenge to locate longer runs.
● These are the
exact counts
S(10N) for selected
N:
N S(10N)
0 1
1 7
2 61
3 608
4 6083
5 60794
6 607926
7 6079291
8 60792694
9 607927124
10 6079270942
11 60792710280
12 607927102274
13 6079271018294
14 60792710185947
16 6079271018540405
18 607927101854022750
24 607927101854026628773299
30 607927101854026628663278087296
36 607927101854026628663276779463775476
6/\(\pi\)2 = 0.607927101854026628663276779258365833...
So you see, you only need to tally up numbers up to
1036 with no repeated prime factors and you'll get an approximation to
\(\pi\) correct to
27 decimal digits !
That's all for now, I hope you enjoyed it. Regrettably, due to a number of factors (pun intended,) I'm now taking a leave of absence from further challenges for a while. Cya.
V.
Edit: rephrased one sentence.
