Is it possible to decode this serial number to determine the year this HP-12C was made?
PHA7370SWQ
PH I assume means it was manufactured in the Philippines?
Thanks for any help
Hi Steve
Thank you for the link, I was not aware of that website.
Philippines,2017,37 weeks
(03-10-2023 02:24 AM)Steve Simpkin Wrote: [ -> ]According to the following site:
https://serial-number-decoder.com/hp-cal...ulator.htm
This HP calculator was made in China during week 37 of 2007 or 2017
Something definitely went wrong there, because a PH serial number is Philippines, not China. I would assume 2017, since in 2007 I think it would have been made in China.
I did think that a China made unit should always start with a CN serial number, e.g: CN40800888
There is a web site that will tell you the warranty date for HP products, although sometimes knowing just the serial number is not enough. In that case, you also need a product number, which isn't always obvious.
https://support.hp.com/us-en/check-warranty
In this particular case, I was able to find that this HP 12C was provided with its factory warranty starting 2017-09-19. I had to know a likely "Product" number for this was F2230A.
