(03-04-2023 03:09 PM)Gil Wrote: [ -> ]And Barbosa's program on EMU48, with Samsung A53:
Less than 13s in approximate mode [/php]for average "1 to 100 000 and seed =1".
Parabéns, Gérson!
Obrigado, Gil!
You can save 100000 additions by not incrementing the counter after the first RAND in each iteration. Also, local variables are evaluated faster than global variables. Try to use only the stack for more speed, especially on not emulated calculator (48G/GX and earlier). Additional optimization in the main loop would make it a bit faster.
It appears iHP48 emulates the HP-48GX faster than the HP50g:
« 0 DUP2 NOT SWAP
START RAND
DO RAND + SWAP 1 + SWAP DUP
UNTIL 1 >
END DROP
NEXT SWAP / 1 +
'X' STO
« TIME 1 RDZ 100000 X TIME ROT HMS-
EVAL
2: 2.71959
1: 0.00153468
Thanks, obrigado.
Minha última versão, com UNTIL
« TIME 1. RDZ 0. 0.
1. 100000.
START
WHILE DUP 1. <=
REPEAT RAND +
SWAP 1. + SWAP
END DROP 0.
NEXT DROP
1000000. / TIME ROT
HMS-
... antes de descobrir a sua, Gérson, bem mais eficiente — que nunca conta, na soma das tentativas, o primeiro número aleatório, que você só acrescenta no final das contas.
Nice too how you used 0 0 and changed one of the two zeroes to 1 for the loop from 1 to 100 000. The DUP2 was nice to get the 0 and keep track, in one step, of the initial 100000 for the final average (division).
Using the 'X' program together with
EVAL
I get with EMU48 on my phone, exact mode,
2.71959
.0045309937 —> 45s, a huge difference in comparison to your 15s (3× your time).
Strange?
(03-04-2023 05:47 PM)Gil Wrote: [ -> ]Minha última versão, com UNTIL
« TIME 1. RDZ 0. 0.
1. 100000.
START
WHILE DUP 1. <=
REPEAT RAND +
SWAP 1. + SWAP
END DROP 0.
NEXT DROP
1000000. / TIME ROT
HMS-
Por outro lado, você usa RAND somente uma vez, o que pode ser importante quando a intenção for minimizar o tamanho. Tive que fazer daquele jeito porque na 42S estava demorando mais de um minuto para 252 iterações. A propósito, WHILE REPEAT END usa 5 bytes a mais que DO UNTIL END.
(On the other hand yours has only one instance of RAND, which might be important if you’re optimizing it for size. I only did it that way because 252 iterations were taking more than one minute on the 42S. By the way, WHILE REPEAT END takes up 22.5 bytes while DO UNTIL END takes up only 17.5).
Your program is significantly faster now, congratulations! (only a minor typo, 1000000 instead of 100000).
(03-04-2023 06:54 PM)Gil Wrote: [ -> ]Using the 'X' program together with
EVAL
2.71959
Strange?
I’ve been using iHP48 on an iPhone:
CALCULATOR
Model: HP48GX
ROM: /ROMs/HP48GX/rom.48g
When I change to model HP50g it takes close to one minute.
(03-04-2023 02:29 PM)Albert Chan Wrote: [ -> ]We expected E*0.5 ≈ S. Here, expected counts estimated with 2S is better than E.
lua> E, 2*S
2.7186766 2.7182611704860222
2S is better estimate than E because *all* generated random numbers are included.
Mean of *all* random numbers = 0.5 is very very good (2 = 1/0.5)
Bonus, increase in accuracy may also comes with speedup. (loops counting not needed)
As suggedted by Barbosa, I selected the model HP48 (instead of HP49-50G) from EMU48.
With exact Barbosa's programs and the above selected model, the elapsed time is now only 11.9s.
However, to try and have better results with model HP49-HP50 from EMU48, I selected approximate mode and put a point (dot) after the digits to transform them from integers into reals. Then, the elapsed time is 12.0s, still a wee bit "worse" than HP48 (from EMU48).
(03-04-2023 09:48 PM)Gil Wrote: [ -> ]However, to try and have better results with model HP49-HP50 from EMU48, I selected approximate mode and put a point (dot) after the digits to transform them from integers into reals. Then, the elapsed time is 12.0s, still a wee bit "worse" than HP48 (from EMU48).
Down to 15.0576s here, timed with TEVAL. It turns out that I had set the 50g model to approximate mode but forgot to edit the program to change the integer constants into real. It’s been a long time since last time I used my 50g, so this’s been useful to dust it off if anything else.
Modifying Gerson's program on the Swiss Micros DM42:
00 {57-Byte Prgm}
01 LBL "CTRND"
02 DATE
03 TIME
04 +
05 SEED
06 RAN
07 1E4
08 ×
09 IP
10 STO 00
11 0
12 STO 01
13 SIGN
14 LBL 00
15 RAN
16 LBL 01
17 X<>Y
18 STO+ 01
19 X<>Y
20 RAN
21 +
22 X<Y?
23 GTO 01
24 R↓
25 DSE ST Y
26 GTO 00
27 RCL 01
48 RCL+ 00
29 RCL÷ 00
30 END
The program starts with assigning a seed of (Time Code + Date Code) as the seed and a random integer up to 10,000 as X. At first the average of the results seem to conjugate towards e, but the trials, it appears the limit may be a different constant:
n = 30
Mean = 2.71830158802 (about 2E-5 from e)
St.Dev = 0.0235108873611
n = 42
Mean = 2.71845315567 (about 1.17E-4 from e)
St.Dev = 0.0201541663394
n = 54
Mean = 2.71967147586 (about 1.38E-3 from e)
St.Dev = 0.019176372560
The samples were taken on March 11, 2023 around 5:30 PM to 5:45 PM (1730 to 1745) Pacific Standard Time.
