02-25-2023, 09:10 PM
Complex base i-1 enables positive and negative integers, and Gaussian integers, to be represented by a nonnegative integer. More information in this paper.
The programs listed here convert between integers or complex numbers and their base i-1 representation. The programs are in the form of a directory because there are several sub-programs and several dependencies.
The directory includes the programs I→DL and DL→I from this thread. These two programs can be removed from this directory if they are already in your path.
The programs I→Bi1 and Bi1→I are for the conversion of positive or negative integers. They are short and fast because they take advantage of simple bit patterns. The programs Z→Bi1 and Bi1→Z are for the conversion of complex numbers (or imaginary numbers in the form of (0, n)). These programs are considerably larger and more.. complex. They are based on the Python programs here. The program Bi1ADD, which is used as a sub-program, adds two numbers encoded in base i-1 without needing to convert them first.
DIR
I\->Bi1
\<< -4. I\->DL 1. @ Convert to base -4
\<< DUP 1. > { 10. + } IFT @ Change 2, 3 to 12, 13
\>> DOLIST 16. DL\->I @ Interpret as base 16
Bi1\->I
\<< 16. I\->DL 1. @ Results will be meaningless unless
\<< DUP 1. > { 10. - } IFT @ all base 16 digits are in {0, 1, 12, 13}
\>> DOLIST -4. DL\->I
Z\->Bi1
\<< 0. RND C\->R SWAP DUP
:: I\->Bi1 { DROP 0. } IFTE SWAP @ Convert real part if not 0
IF DUP
THEN DUP 0. <
{ NEG 7. } 3. IFTE Bi1IM @ Convert imaginary part if not 0
ELSE DROP
END
Bi1\->Z
\<< 2. I\->DL (-1.,1.) DL\->I @ Convert to base 2, interpret as base -1+i
Bi1ADD
\<< 64. STWS 2340. # 0h 0. \-> sum sh
WHILE PICK3 PICK3 OR
{ 2340. 2258. } PICK3 POS NOT OR
REPEAT { 2560. 1976. 2048. 1464. }
OVER 2. / IP 4. MOD 1. + GET
SWAP 8. / IP + PICK3 2. MOD +
OVER 2. MOD + sum OVER 2. MOD
2. sh ^ * R\->B OR 'sum' STO
'sh' 1. STO+ ROT 2. / IP ROT 2. / IP ROT
END DROP DROP2 sum B\->R
Bi1IM
WHILE OVER
REPEAT OVER 2. MOD
{ ROT OVER Bi1ADD ROT ROT }
IFT SWAP 2. / IP SWAP DUP Bi1ADD
END DROP2
I\->DL
\<< DUP ABS SWAP 0 < DEPTH 3. - \-> b f d
WHILE b DUP2 / FLOOR ROT ROT MOD
DEPTH d - ROLLD DUP
REPEAT f
:: NEG IFT
END DROP DEPTH d - \->LIST
DL\->I
\<< \-> b
\<< OBJ\->
IF DUP 1. >
THEN 1 SWAP 2. SWAP
START b * ROT OVER * ROT + SWAP
NEXT
END DROP
END
