02-05-2023, 06:59 PM
Dear all,
I got an HP35 in bad shape very cheap and decided to take on the challenge to revive it. (Read: I gotta get a life!)
I dunno what the previous owner did to this calc, but it suffered severe corrosion, presumably from a leaked battery pack. As a result, two tracks (RCD and Vss) on the display/keyboard PCB were corroded through. I soaked the whole thing in citric acid (coffee machine descaler) and distilled water to neutralise and clean up the mess, and repaired the broken traces with a combination of copper tape and solder (to keep the profile flat). AND IT WORKED... for 15 minutes or so. Then it just suddenly locked up with a stuck display. When I power it up now the display faintly flashes for a few msec and stays dark.
I've consulted Jacques Laporte's excellent website on the HP-35, and verified that all derived voltages (Vcc, Vgg and Vss) are in spec, and that both clocks (phi1 and phi2) are present, ditto SYNC. The keyboard matrix is also being scanned via the R1-R8 C1-C5 lines. However, there is no activity on the D0-D4 lines going to the anode driver, so nothing is displayed. The IA and IS lines to/from the ROMs are stuck in a fixed pattern, even immediately after powerup, so there's no activity there.
Is there anything further I could check or should I just give up and assume one of the ROMs or the C&T chip has failed? (To be fair, the logic PCB looks remarkably clean and free from corrosion).
Any hint appreciated. Many thanks and have a good week,
--Roland
--Roland
