Full Version: WYSIWYG editor in a computer algebra language
Hello
I leave you a link to a series of videos that show the execution of the source code of the fractals ported from BASIC to SMathStudio language
by Dr. Urroz Gilberto E.
Initial video in Spanish:
https://youtu.be/z6ehLEEb714?list=PLxR0Y...4acH4pt8Qg
Initial video in English:
What innovation does the SMathStudio programming language have? Since it does not require keywords to close the cyclic structures and so on, since it uses the tabulation with vertical lines to navigate a structure as shown in the following image
[Image: ?file=738367&type=image]
This idea should be replicated in modern calculator languages.
(01-23-2023 12:10 AM)compsystems Wrote: [ -> ]Hello
Yes, Smath provides a WYSIWYG Mathcad-like environment that nicely blends code and plots, but note that unlike the example in your post, the Tree2 and Sierpinski programs in the video use multiple levels of indentation (e.g., three increasingly shifted levels of vertical lines) that would be a challenging (and inefficient) use of calculator display real estate.
Another observation is that, while the translation from BASIC code to Smath was facilitated by BASIC's universal pseudo-code appearance, a glance at the Tree2 and Sierpinski programs in the video make it clear that translation from Smath into other programming languages would neither be trivial nor fun.
Thanks for the interesting video!
(01-23-2023 12:10 AM)compsystems Wrote: [ -> ]What innovation does the SMathStudio programming language have? Since it does not require keywords to close the cyclic structures and so on, since it uses the tabulation with vertical lines to navigate a structure as shown in the following image
This reminds me of the way Python does things. That's why I'm not a big fan of Python. It's easy to lose track of indents. Putting a statement in the wrong column can change the whole meaning of a program. In BASIC,
If x>7 THEN
y=2
b=3
END IF
means the same thing as
IF x>7 THEN
  y=2
b=3
END IF
Whereas
if x==7:
  y=2
  b=3
is different than
if x==7:
  y=2
b=3
In fact posting BASIC code here by simply cutting and pasting the text into a message would work fine. Trying that with Python without code brackets would ruin the program since leading spaces are removed.
