Wondering if this is possible without tearing it. I have an HP-32E with the overlay losing adhesion around the Enter key. Otherwise, it's an excellent machine. Ideally, I would like to peel the entire overlay off, lay down some adhesive and re apply the overlay. Has anyone had luck with this?
-John
Hi John
If you consider to tear it off maybe the same adhesive spray will work Alberto applied for the classic's instruction label?
I'm sure you must fully disassemble the calculator, take the keys out and then work similar as Alberto did.
See here:
https://www.hpmuseum.org/forum/thread-15865.html
Don't know it will work at spices as well. Good luck.
Keep as posted.
Andi
