12-16-2022, 10:29 PM
XRPN s now available in version 1.2. You can now easily install the programming language with:
From the documentation:
Full documentation is available here
gem install xrpn
Quote:XRPN is a superset of FOCAL (Forty One CALculator Language). The bulk of the documentation is found in the user manuals for the HP-41CX calculator (Vol 1 & Vol 2).
XRPN accepts both the original HP-41 command and also the XRPN format. Since XRPN has a limit on certain characters used in the commands, the system internally converts some of the HP-41 commands to the XRPN equivalent. While the internal functions/commands in XRPN are lower case, you are free to write them in UPPER, lower or CaMeL case as you wish.
