In calculus there is a method for finding several roots of a function called deflation.
When a root is found, that’s root one, r1.
To find the next root, the function becomes f(x)/(x-r1). If a root is found, that’s root two, r2.
To find the next root, the function to solve is (f(x)/(x-r1))/(x-r2)
My question is, to make this repetitive process easier, I’d like to just modify the function accordingly to find successive root. Problem is that after I find a root, I can’t just store the result in a variable and keep the function intact so I can continue editing it for finding the next root.
The way I need to exit the solver, erases the function I’m evaluating.
How can I retain the function so I can edit it to find successive roots on the 991EX Classwiz, fx-991ES Plus, and fx-115ES Plus?
(11-13-2022 07:01 AM)Matt Agajanian Wrote: [ -> ]The way I need to exit the solver, erases the function I’m evaluating.
First evaluate your function with CALC, with this step your function stored in History.
Then use SOLVE
When your root is on the screen (x=...; L-R=0) press STO A
Go up to your stored equation, bracket it () and press fraction button: with this step your function goes to fraction numerator and you can add (x-A) into denominator
From here same as above:
Evaluate your function with CALC, type for x any value which is not equal A
SOLVE
.... STO B
.... (x-B)
Next root is same as above again:
.... STO C
.... (x-C)
Although the keystrokes were kinda blocked due to hands covering the keyboard, your description of the keystrokes helped!
Now, let’s see if the Sharp cooperates.
DRUMROLL, PLEASE!
And yes it does!!
The trick, after a root is found, exit by pressing ON/C. This brings up the equation with the cursor at the end of the equation. Press =
Then, store X into A (first root)
Move back up to the equation. Editing is enabled. So, bracket the equation in parentheses and add /(x-a).
Press SOLVER.
Enter an initial guess.
Adjust dx if you wish.
Press =
Once a root is found, Press ON/C
The cursor is at the end of f(x), press =. This will add f(x) to the history list.
Recall X and store in B as this is the second root.
Move back up the history to edit the f(x) you solved. Bracket it and add / (x-b).
Press SOLVER.
(11-16-2022 05:57 AM)Thomas Klemm Wrote: [ -> ]analemma - Are you into sundials?
Not really, but I use it for sunrise-noon-sunset calculations.
You can download here the HiRes version: Analemma curve HiRes
And a video about the calculation + how you can insert the analemma into calculator case (video timing set to 40:15, but Youtube not enough clever to understand... Damn...):
