Full Version: generator issues
I am trying to port a deflate compression algorithm to the Prime's Python interpreter using this as a base. I have modified the code so that it only uses functions that are included in the calculator's small library. Running this code on my PC in CPython 3.8 gives the decoded string as desired, but on the calculator, it outputs nothing. (I noticed that the main generator stops iteration on its first call)
data = b'<redacted>'
def counter(s):
    output = {}
    for c in s:
        try:
            output[c] += 1
        except KeyError:
            output[c] = 1
    return output
def stream_inflate(chunk_size=65536):
    length_extra_bits_diffs = (
        (0, 3), (0, 4), (0, 5), (0, 6), (0, 7), (0, 8), (0, 9), (0, 10),
        (1, 11), (1, 13), (1, 15), (1, 17),
        (2, 19), (2, 23), (2, 27), (2, 31),
        (3, 35), (3, 43), (3, 51), (3, 59),
        (4, 67), (4, 83), (4, 99), (4, 115),
        (5, 131), (5, 163), (5, 195), (5, 227),
        (0, 258),
    dist_extra_bits_diffs = (
        (0, 1), (0, 2), (0, 3), (0, 4),
        (1, 5), (1, 7), (2, 9), (2, 13),
        (3, 17), (3, 25), (4, 33), (4, 49),
        (5, 65), (5, 97), (6, 129), (6, 193),
        (7, 257), (7, 385), (8, 513), (8, 769),
        (9, 1025), (9, 1537), (10, 2049), (10, 3073),
        (11, 4097), (11, 6145), (12, 8193), (12, 12289),
        (13, 16385), (13, 24577),
    cache_size = 32768
    return _stream_inflate(length_extra_bits_diffs, dist_extra_bits_diffs, cache_size, chunk_size)
def stream_inflate64(chunk_size=65536):
        (16, 3),
        (13, 16385), (13, 24577), (14, 32769), (14, 49153),
    cache_size = 65536
def _stream_inflate(length_extra_bits_diffs, dist_extra_bits_diffs, cache_size, chunk_size):
    literal_stop_or_length_code_lengths = \
        (8,) * 144 + \
        (9,) * 112 + \
        (7,) * 24 + \
        (8,) * 8
    dist_code_lengths = \
        (5,) * 32
    code_lengths_alphabet = (16, 17, 18, 0, 8, 7, 9, 6, 10, 5, 11, 4, 12, 3, 13, 2, 14, 1, 15)
    # An object that can be seen as a "deferred" that can pause a generator, with
    # the extra abiltiy to yield values by the generator "runner".
    def get_iterable_queue():
        iter_queue = []
        it = None
        def _append(iterable):
            iter_queue[0:0] = [next(iterable)]
        def _next():
            nonlocal it
            while True:
                if it is None:
                    try:
                        it = iter(iter_queue.pop, object())
                    except Exception:
                        raise StopIteration() from None
                try:
                    return next(it)
                except StopIteration:
                    it = None
        return _append, _next
    # Low level bit/byte readers
    def get_readers(it_next):
        chunk = b''
        offset_byte = 0
        offset_bit = 0
        def _has_bit():
            nonlocal chunk, offset_byte, offset_bit
            if offset_bit == 8:
                offset_bit = 0
                offset_byte += 1
            if offset_byte == len(chunk):
                try:
                    chunk = it_next()
                    return False
                else:
                    offset_byte = 0
                    offset_bit = 0
            return True
        def _has_byte():
            if offset_bit:
                offset_byte += 1
            offset_bit = 0
            return _has_bit()
        def _get_bit():
            nonlocal offset_bit
            offset_bit += 1
            return (chunk[offset_byte] & (2 ** (offset_bit - 1))) >> (offset_bit - 1)
        def _get_byte():
            nonlocal offset_byte
            offset_byte += 1
            return chunk[offset_byte - 1]
        def _yield_bytes_up_to(num):
            if offset_bit:
                offset_byte += 1
            offset_bit = 0
            while num:
                    try:
                        chunk = it_next()
                        return
                    offset_byte = 0
                to_yield = min(num, len(chunk) - offset_byte)
                offset_byte += to_yield
                num -= to_yield
                yield chunk[offset_byte - to_yield:offset_byte]
        def _num_bytes_unconsumed():
            return len(chunk) - offset_byte - (1 if offset_bit else 0)
        return _has_bit, _has_byte, _get_bit, _get_byte, _yield_bytes_up_to, _num_bytes_unconsumed
    # Bit/byte readers that are DeferredYielder
    def get_deferred_yielder_readers(reader_has_bit, reader_has_byte, reader_get_bit, reader_get_byte,
                                     reader_yield_bytes_up_to):
        get_bit = (reader_has_bit, lambda: (), lambda: (0, 0), reader_get_bit)
        get_byte = (reader_has_byte, lambda: (), lambda: (0, 0), reader_get_byte)
        def get_bits(num_bits):
            out = bytearray(-(-num_bits // 8))
            out_offset_bit = 0
            while num_bits:
                bit = yield get_bit
                out[out_offset_bit // 8] |= bit << (out_offset_bit % 8)
                num_bits -= 1
                out_offset_bit += 1
            return bytes(out)
        def get_bytes(num_bytes):
            out = bytearray(num_bytes)
            out_offset = 0
            while out_offset != num_bytes:
                out[out_offset] = yield get_byte
                out_offset += 1
            return bytes(out)
        def yield_bytes(num_bytes):
            def to_yield():
                nonlocal num_bytes
                for chunk in reader_yield_bytes_up_to(num_bytes):
                    num_bytes -= len(chunk)
                    yield chunk
            yield_bytes_up_to = (reader_has_byte, to_yield, lambda: (0, 0), lambda: None)
            while num_bytes:
                yield yield_bytes_up_to
        return get_bits, get_bytes, yield_bytes
    def get_backwards_cache(size):
        cache = bytearray(size)
        cache_start = 0
        cache_len = 0
        def via_cache(bytes_iter):
            nonlocal cache, cache_start, cache_len
            for chunk in bytes_iter:
                chunk_start = max(len(chunk) - size, 0)
                chunk_end = len(chunk)
                chunk_len = chunk_end - chunk_start
                part_1_start = (cache_start + cache_len) % size
                part_1_end = min(part_1_start + chunk_len, size)
                part_1_chunk_start = chunk_start
                part_1_chunk_end = chunk_start + (part_1_end - part_1_start)
                part_2_start = 0
                part_2_end = chunk_len - (part_1_end - part_1_start)
                part_2_chunk_start = part_1_chunk_end
                part_2_chunk_end = part_1_chunk_end + (part_2_end - part_2_start)
                cache_len_over_size = max((cache_len + chunk_len) - size, 0)
                cache_len = min(size, cache_len + chunk_len)
                cache_start = (cache_start + cache_len_over_size) % size
                cache[part_1_start:part_1_end] = chunk[part_1_chunk_start:part_1_chunk_end]
                cache[part_2_start:part_2_end] = chunk[part_2_chunk_start:part_2_chunk_end]
                yield chunk
        def from_cache(dist, length):
            if dist > cache_len:
                raise Exception('Searching backwards too far', dist, len(cache))
            available = dist
            part_1_start = (cache_start + cache_len - dist) % size
            part_1_end = min(part_1_start + available, size)
            part_2_start = 0
            part_2_end = max(available - (part_1_end - part_1_start), 0)
            while length:
                to_yield = cache[part_1_start:part_1_end][:length]
                length -= len(to_yield)
                yield to_yield
                to_yield = cache[part_2_start:part_2_end][:length]
                yield to_yield
        return via_cache, from_cache
    def get_runner(append, via_cache, from_cache, alg):
        is_done = False
        can_proceed, to_yield, num_from_cache, return_value = None, None, None, None
        def _is_done():
            return is_done
        def _run(new_iterable):
            nonlocal is_done, can_proceed, to_yield, num_from_cache, return_value
            append(new_iterable)
            while True:
                if can_proceed is None:
                    try:
                        can_proceed, to_yield, num_from_cache, return_value = \
                            next(alg) if return_value is None else \
                                alg.send(return_value())
                        break
                if not can_proceed():
                    return
                yield from via_cache(to_yield())
                yield from via_cache(from_cache(*num_from_cache()))
                can_proceed = None
            is_done = True
        return _run, _is_done
    def paginate(get_bytes_iter, page_size):
        def _paginate(bytes_iter):
            chunk = b''
            offset = 0
            it = iter(bytes_iter)
            def up_to_page_size(num):
                while num:
                    if offset == len(chunk):
                        try:
                            chunk = next(it)
                            break
                        else:
                            offset = 0
                    to_yield = min(num, len(chunk) - offset)
                    offset = offset + to_yield
                    num -= to_yield
                    yield chunk[offset - to_yield:offset]
            while True:
                page = b''.join(up_to_page_size(page_size))
                if not page:
                    break
                yield page
        def _run(*args, **kwargs):
            yield from _paginate(get_bytes_iter(*args, **kwargs))
        return _run
    def get_huffman_codes(lengths):
        def yield_codes():
            max_bits = max(lengths)
            bl_count = counter(lengths)
            next_code = {}
            code = 0
            bl_count[0] = 0
            for bits in range(1, max_bits + 1):
                try:
                    code = (code + bl_count[bits - 1]) << 1
                except KeyError:
                    bl_count[bits - 1] = 0
                next_code[bits] = code
            for value, length in enumerate(lengths):
                if length != 0:
                    next_code[length] += 1
                    yield (length, next_code[length] - 1), value
        return dict(yield_codes())
    def get_huffman_value(get_bits, codes):
        length = 0
        code = 0
        while True:
            length += 1
            code = (code << 1) | ord((yield from get_bits(1)))
            try:
                return codes[(length, code)]
            except KeyError:
                continue
    def get_code_length_code_lengths(num_length_codes, get_bits):
        result = [0] * num_length_codes
        for i in range(0, num_length_codes):
            result[i] = ord((yield from get_bits(3)))
        return tuple(result)
    def get_code_lengths(get_bits, code_length_codes, num_codes):
        result = [0] * num_codes
        i = 0
        previous = None
        while i < num_codes:
            code = yield from get_huffman_value(get_bits, code_length_codes)
            if code < 16:
                previous = code
                result[i] = code
                i += 1
            elif code == 16:
                for _ in range(0, 3 + ord((yield from get_bits(2)))):
                    result[i] = previous
                    i += 1
            elif code == 17:
                i += 3 + ord((yield from get_bits(3)))
                previous = 0
            elif code == 18:
                i += 11 + ord((yield from get_bits(7)))
                previous = 0
        return result
    def yield_exactly(bytes_to_yield):
        return (lambda: True, lambda: (bytes_to_yield,), lambda: (0, 0), lambda: None)
    def yield_from_cache(dist, length):
        return (lambda: True, lambda: (), lambda: (dist, length), lambda: None)
    def inflate(get_bits, get_bytes, yield_bytes):
        b_final = b'\0'
        while not b_final[0]:
            b_final = yield from get_bits(1)
            b_type = yield from get_bits(2)
            if b_type == b'\3':
                raise Exception("Unsupported block type")
            if b_type == b'\0':
                b_len = int.from_bytes((yield from get_bytes(2)), byteorder='little')
                yield from yield_bytes(b_len)
                continue
            if b_type == b'\1':
                literal_stop_or_length_codes = get_huffman_codes(literal_stop_or_length_code_lengths)
                backwards_dist_codes = get_huffman_codes(dist_code_lengths)
            else:
                num_literal_length_codes = ord((yield from get_bits(5))) + 257
                num_dist_codes = ord((yield from get_bits(5))) + 1
                num_length_codes = ord((yield from get_bits(4))) + 4
                code_length_code_lengths = (yield from get_code_length_code_lengths(num_length_codes, get_bits)) + (
                        (0,) * (19 - num_length_codes))
                code_length_code_lengths = tuple(
                    v for i, v in
                    sorted(enumerate(code_length_code_lengths), key=lambda x: code_lengths_alphabet[x[0]])
                code_length_codes = get_huffman_codes(code_length_code_lengths)
                dynamic_code_lengths = yield from get_code_lengths(get_bits, code_length_codes,
        num_literal_length_codes + num_dist_codes)
                dynamic_literal_code_lengths = dynamic_code_lengths[:num_literal_length_codes]
                dynamic_dist_code_lengths = dynamic_code_lengths[num_literal_length_codes:]
                literal_stop_or_length_codes = get_huffman_codes(dynamic_literal_code_lengths)
                backwards_dist_codes = get_huffman_codes(dynamic_dist_code_lengths)
            while True:
                literal_stop_or_length_code = yield from get_huffman_value(get_bits, literal_stop_or_length_codes)
                if literal_stop_or_length_code < 256:
                    yield yield_exactly(bytes((literal_stop_or_length_code,)))
                elif literal_stop_or_length_code == 256:
                    break
                else:
                    length_extra_bits, length_diff = length_extra_bits_diffs[literal_stop_or_length_code - 257]
                    length_extra = int.from_bytes((yield from get_bits(length_extra_bits)), byteorder='little')
                    code = yield from get_huffman_value(get_bits, backwards_dist_codes)
                    dist_extra_bits, dist_diff = dist_extra_bits_diffs[code]
                    dist_extra = int.from_bytes((yield from get_bits(dist_extra_bits)), byteorder='little')
                    yield yield_from_cache(dist=dist_extra + dist_diff, length=length_extra + length_diff)
    it_append, it_next = get_iterable_queue()
    reader_has_bit, reader_has_byte, reader_get_bit, reader_get_byte, reader_yield_bytes_up_to, reader_num_bytes_unconsumed = get_readers(
        it_next)
    get_bits, get_bytes, yield_bytes = get_deferred_yielder_readers(reader_has_bit, reader_has_byte, reader_get_bit,
        reader_get_byte, reader_yield_bytes_up_to)
    via_cache, from_cache = get_backwards_cache(cache_size)
    run, is_done = get_runner(it_append, via_cache, from_cache, inflate(get_bits, get_bytes, yield_bytes))
    return paginate(run, chunk_size), is_done, reader_num_bytes_unconsumed
def compressed_chunks():
    # Iterable that yields the bytes of a DEFLATE-compressed stream
    yield data
for uncompressed_chunk in stream_inflate()[0](compressed_chunks()):
    print(uncompressed_chunk)
