Full Version: Curvature
Gratitude to Arno K. and rombio for helping me with derivatives and CAS programs.
The following CAS functions calculates the curvature of:
functions, y(x)
polar functions, r(t) (t: Θ)
parametric functions, x(t), y(t)
Let Δα be the angle of rotation angle and Δs is the slight change of distance. Then the radius of curvature is:
K = abs(Δα ÷ Δs) as Δs → 0
And the radius of curvature is the reciprocal of K.
For circles, the radius of curvature is constant. Wankel engines and rotary engines have their pistons traveling in a circle.
Calculating the curvature depends on the form of the function.
Function: y(x)
K = abs( y''(x) ) ÷ (1 + (y'(x))^2) ^(3/2)
Polar: r(t) (t replaces Θ)
K = abs( r(t)^2 + 2 * (r'(t))^2 - r(t) * r''(t) ) ÷ ( r(t)^2 + r'(t)^2 )^(3/2)
Parametric: x(t), y(t)
K = abs( x'(t) * y''(t) - y'(t) * x''(t) ) ÷ ( x'(t)^2 + y'(t)^2 )^(3/2)
Radius of Curvature:
r = 1 ÷ K
HP Prime CAS Program: crvfunc
#cas
crvfunc(y,x):=
// curvature
// function
// radius = 1/curvature
LOCAL a,b;
a:=diff(y,x,2);
b:=diff(y,x,1);
RETURN ABS(a)/(1+b^2)^(3/2);
#end
HP Prime CAS Program: crvpol
#cas
crvpol(r,t):=
// curvature
// polar (t: θ)
LOCAL a,b,n,d;
a:=diff(r,t,2);
b:=diff(r,t,1);
n:=simplify(r^2+2*b^2-r*a);
d:=r^2+b^2;
RETURN ABS(n)/(d)^(3/2);
#end
HP Prime CAS Program: crvpar
#cas
crvpar(y,x,t):=
// curvature
// parametric
LOCAL y1,y2,x1,x2,n,d;
y2:=diff(y,t,2);
y1:=diff(y,t,1);
x2:=diff(x,t,2);
x1:=diff(x,t,1);
n:=simplify(x1*y2-y1*x2);
d:=simplify(x1^2+y1^2);
#end
Source:
Svirin, Alex Ph.D. "Curvature and Radius of Curvature" Math24 https://math24.net/curvature-radius.html 2022. Last Updated September 12, 2022.
