Do you just mean the Venn diagrams?
If so then you could use something like this, although I really hope there is a better way.
EXPORT RQST()
FOR Y FROM 0 TO 239 DO
FOR X FROM 0 TO 319 DO
IF (X-120)^2+(Y-120)^2<80^2 THEN
PIXON_P(X,Y,RGB(255,0,0));
IF (X-180)^2+(Y-120)^2<80^2 THEN
PIXON_P(X,Y,RGB(0,255,0));
IF (X-180)^2+(Y-120)^2<80^2 AND (X-120)^2+(Y-120)^2<80^2 THEN
PIXON_P(X,Y,RGB(0,0,255));
(09-30-2022 06:02 AM)DrEureka Wrote: [ -> ]Hello, I wanted to know if you know of any program that allows me to do this type of joints, for the hp prime.
Thx!
More info = https://www.math.net/union or https://www.math.net/set-theory
Prime has a union command
Syntax:
UNION(list1 or object1, ... list_n or object_n)
UNION concatenates the inputs, removing all duplicates.
Example:
UNION({1,2,3}, {2,4,8}, 10) → {1, 2, 3, 4, 8, 10}
Not only UNION, there are INTERSECT and DIFFERENCE, too.
Arno
(09-30-2022 03:15 PM)matalog Wrote: [ -> ]Do you just mean the Venn diagrams?
EXPORT RQST()
I'll check it out, thank you very much. yes from venn diagram
EXPORT RQST()
I ask you a question, do you have an example of use, how can I enter several variables? How can I discriminate by UNION, INTERSECT and DIFFERENCE? thanks again for sharing
(09-30-2022 03:57 PM)DrEureka Wrote: [ -> ] (09-30-2022 03:15 PM)matalog Wrote: [ -> ]Do you just mean the Venn diagrams?
EXPORT RQST()
This is a little more optimised, but there must be a much faster way of doing it:
EXPORT RQST()
LOCAL R=80^2;
LOCAL S:=0;
LOCAL T:=0;
LOCAL U:=0;
U:=(Y-120)^2;
S:=(X-120)^2+U<R;
T:=(X-180)^2+U<R;
IF S THEN
IF T THEN
IF S AND T THEN
The way I showed earlier is customisable.
This will do a very similar thing, just less customisable, but much, much faster.
EXPORT RQST()
ARC_P(G0,120,120,80,0,360,{RGB(0,0,255,128),RGB(0,0,255,128)});
ARC_P(G0,180,120,80,0,360,{RGB(255,0,0,128),RGB(255,0,0,128)});
WAIT(-1)
