09-18-2022, 09:32 PM
09-18-2022, 10:34 PM
Registers 20 to 59 are directly accessible once you have installed the related memory ICs inside the SR-52.
09-18-2022, 10:44 PM
I presume you needed to send the 52 back to TI so they could install the ICs. Was it a substitution of ICs or were they installed in an open socket?
09-19-2022, 12:59 AM
TI would not install additional chips of any kind. No manufacturer would do that at the time and probably not today.
A google search would turn this up Matt:
http://www.datamath.org/Sci/WEDGE/sr-52_...ented.html
Will help if you are able to do that type of thing in advance and post the results here. :-)
09-19-2022, 02:03 AM
(09-19-2022 12:59 AM)Gene Wrote: [ -> ]TI would not install additional chips of any kind. No manufacturer would do that at the time and probably not today.
In any case, thanks for finding the info.
09-19-2022, 06:41 AM
(09-18-2022 10:44 PM)Matt Agajanian Wrote: [ -> ]I presume you needed to send the 52 back to TI so they could install the ICs. Was it a substitution of ICs or were they installed in an open socket?
There is no open socket for that on the SR-52 however Texas Instruments was selling the TMC0599 Multi-Register chips to the public and some SR-52 users found the way to add them into the SR-52 to get more registers available.
This was published in 52-Notes V5N2p3:
Quote:Adding Chips (52): TI is now making available to the public the TMC 0599 chip via
Mr S Riggs, Box 53, Lubbock, TX 79408 for $17.77 each. Reportedly, 2 of these will
provide the missing SR-52 registers (20-59) if properly installed. Michael Rak (502)
has obtained details from a TI source, and if you are experienced at assembling
modern electronics components and are willing to risk machine damage, send 25ยข
and a SASE to Mike at 1823 El Cerrito Pl #F Los Angeles, CA 90068 for a copy of his
info. Neither Mike, nor TI nor the SR-52 Users Club assumes any responsibility
whatsoever for any consequences which might arise from chip ad-on mods. TI does
not now, and does not plan to perform this mod for the general public.
You can see such modification done here. I have modified this way my SR-52A which has now 50 user memory registers instead of 20 with the addition of a single TMC0599.
09-19-2022, 12:18 PM
Thanks for these notes and the link Didier, I never knew about this option to expand the SR-52 memory, pretty interesting!
09-19-2022, 06:59 PM
(09-19-2022 12:18 PM)rprosperi Wrote: [ -> ]Thanks for these notes and the link Didier, I never knew about this option to expand the SR-52 memory, pretty interesting!
Agreed! Interesting and fascinating. Congratulations on your 52A. Enjoy.
09-19-2022, 11:47 PM
Matt, don't get me wrong.
I'm simply suggesting that you google first and post what you find here. Try it and be a provider of information rather than asking questions only. :-)
Gene
Gene
09-19-2022, 11:54 PM
(09-19-2022 11:47 PM)Gene Wrote: [ -> ]Matt, don't get me wrong.
Gene
Okay.
