Hi all, I am learning math and learning how to use the HP Prime as well.
How do I factorize 4x^2+36xy+81y^2 and get (2x+9y)^2 as a result?
Things I've tried in CAS view:
- factor(4x^2+36xy+81y^2) -> 36xy+4x^2+81y^2
- factors(4x^2+36xy+81y^2) -> [4*x^2+81*y^2+36*xy,1]
- simplify(4x^2+36xy+81y^2) -> 4x^2+36xy+81y^2
- collect(4x^2+36xy+81y^2) -> 4x^2+81y^2+36xy
- cfactor(4x^2+36xy+81y^2) -> 4x^2+81y^2+36xy
(08-23-2022 12:02 PM)rancom Wrote: [ -> ]Hi all, I am learning math and learning how to use the HP Prime as well.
You have to put the multiplication sign between the numbers, the variable "x" and the variable "y".
Add a * between x and y, otherwise xy is interpreted as a single variable with a name identifier of length 2.
(08-23-2022 05:16 PM)robmio Wrote: [ -> ][quote='rancom' pid='163314' dateline='1661256139']
(08-23-2022 05:16 PM)robmio Wrote: [ -> ] (08-23-2022 12:02 PM)rancom Wrote: [ -> ]Hi all, I am learning math and learning how to use the HP Prime as well.
I don't believe you have to put a multiplication symbol between a number and its variable when entering the equation. For example entering; factor(4x^2+36x*y+81y^2) appears to be automatically interpreted as factor(4*x^2+36x*y+81*y^2) without having to enter the * after the 4, 36 or 81.
attachment=11014]
(08-23-2022 05:30 PM)Steve Simpkin Wrote: [ -> ] (08-23-2022 05:16 PM)robmio Wrote: [ -> ]You have to put the multiplication sign between the numbers, the variable "x" and the variable "y".
Wow, I didn't know. Thank you so much for letting me know this possibility.
Regards, Roberto
It's beginning to look like Facebook here fellas, 1 or 2 of the same answers are probably enough... LOL
(08-23-2022 05:48 PM)rprosperi Wrote: [ -> ]It's beginning to look like Facebook here fellas, 1 or 2 of the same answers are probably enough... LOL
Oh, go put a multiplication sign in that!
I know that answers don't show up immediately for me so sometimes I answer a question that's been answered two or three times (or more!) before I see them.
I found out the answer guys, I have to add a multiplication sign between x and y.
In all seriousness, thank you all for this info!
