08-10-2022, 03:28 PM
08-10-2022, 03:55 PM
One way I can think of to do it is with SYMB2POLY
08-11-2022, 05:50 PM
dsfantos wrote:
You are absolutely right: Simplify does not change anything.
If you apply epand to the expression you get:
4.2W^3 - 20.8*w^2+4.1*w+4.1+20.5*w-4.1 which is quite near to what you wanted.
Applying simplify to the result again does not change anything. Indeed this is very easy to simplify. A 5th grade pupil should see that +4.1 and -4.1 could be combined. A CAS-system should be able to do it.
Applying collect delivers a somewhat other result I am not sure whether this is correct:
4.2*w*(w-3.)*(w-1.952381)
08-11-2022, 06:04 PM
(08-11-2022 05:50 PM)rawi Wrote: [ -> ]dsfantos wrote:Quote:with simplify it doesn't work
Apply expand twice to get the first expected result.
08-16-2022, 05:34 PM
thanks!!!
Thats work!!!!
Thats work!!!!
