I get crashes often using matrices, especially viewing them after a calculation. I will need to track down the exact steps to replicate it, but I'm using the latest two file version posted at Bernard's site (1.7.0) on a CG50.
https://www-fourier.univ-grenoble-alpes....sse/casio/
I wasn't sure where to post this, hopefully it will be useful to debug once I retrace the steps.
Picture:
https://imgur.com/hju8uCc
(07-31-2022 06:37 PM)khaoskosmos Wrote: [ -> ]I get crashes often using matrices, especially viewing them after a calculation. I will need to track down the exact steps to replicate it, but I'm using the latest two file version posted at Bernard's site (1.7.0) on a CG50.
Picture:
Yes, please provide some steps to reproduce the crash. Then I can debug on the Numworks simulator or TI Nspire emulator and port the fix to the Casio.
(08-01-2022 08:55 PM)parisse Wrote: [ -> ] (07-31-2022 06:37 PM)khaoskosmos Wrote: [ -> ]I get crashes often using matrices, especially viewing them after a calculation. I will need to track down the exact steps to replicate it, but I'm using the latest two file version posted at Bernard's site (1.7.0) on a CG50.
Picture:
Well, thank goodness Calculator Politics aren't totally polarized and damaged like most other politics these days! Here's a collaborative discussion about how to use a Numworks or TI tool to fix a Casio product, enabled by discussion on an HP Forum, and it's all a good thing!!
Thanks gentlemen and please do carry on....
(08-02-2022 12:13 AM)rprosperi Wrote: [ -> ] (08-01-2022 08:55 PM)parisse Wrote: [ -> ]Yes, please provide some steps to reproduce the crash. Then I can debug on the Numworks simulator or TI Nspire emulator and port the fix to the Casio.
I thought the very same when reading Bernard's response.
Ok, I've crashed it a couple ways, but this last time was just multiplication of the 3x5 matrix by a scalar:
https://youtu.be/6wkBKjQjmBY
I had a typo entering U at one point, and I also exited the matrix editor so I had to go back. These additional steps don't make a difference to the crash.
The HP Prime is holding the CG50 up to make it relevant
Edit: not related or important, but the algb soft key alternates between centered and left aligned.
Thanks, but the video is unfortunately not very helpful for me. I see that you edit a 3*5 matrix named A, then you enter A in the shell, got the answer, then type 2*A, the answer is displayed in the matrixwriter, then it crashes, but I do not see which key you pressed to get the crash. I check myself a matrix creation A, then 2*A and got everything fine. It might be that your Khicas history is corrupted in some way.
I recommend that you erase your history: from Casio Memory app, erase session.xw. Then run Khicas again, try again to edit a matrix A and see if 2*A raises a crash. If the crash depends on the matrix value, instead of a video, try to report all textually. For example, tell us that A was a 3x5 matrix with value say A:=[[1,2,3,4,5],[0,0,0,0,0],[1,1,1,2,3]] and typing 2*A then pressing twice RIGHT and once UP raises a crash.
So far, no more crashing after erasing session.xw
I was able to multiply matrix A by a scalar and also calculated the nullspace with -trn(ker(A)), both executed as expected. I will update if I encounter the exact steps/key presses that corrupted the session.
I still have not tracked down the exact steps, but I think transpose is one function that causes crashes.
Using the matrix editor and and a couple matrix functions on those matrices usually causes a crash.
The last thing I did to crash was type the following, hit EXE
B:=eval(transpose(transpose([[1,2,3],[4,5,6]])))
I added the eval because noticed that the results had transpose written out instead of performed when I viewed the results. That did not help, I was able to see the results (with the function transpose), and then the calculator crashed.
![[Image: IMG-20220808-194153-01.jpg]](https://i.ibb.co/YLvm6DF/IMG-20220808-194153-01.jpg)
Quick note, I was using transpose from cmds -> 3 Linear algebra -> 15 transpose(A)
This seems to be broken? I get normal results (a correct transposed matrix) when I use trn(A) but transpose(A) repeats the function into the output.
