Thank You. Each of your answers was spot on.
I apologize for the length of the following question
Could you provide some insight into the xTheta key? In general I have a hard time getting solve to work in CAS mode. Folks mention it is because the equations are numeric and not symbolic.
I ask these questions because when I try to experiment I get syntax errors so some guidance would be helpful. . .
I know I will have a syntax error or some error when the exTheta produces an "a" or "A" but when it provides a variable in the form of "x" it always seems to work.
To add more confusion to my mind on the subject I see multiple ways to invoke the solve operation:
OPTION 1
-Set up HOME >> APP >> SOLVE
-hit esc to exit to command-line mode "Solve" is in the title bar.
Do I then hit the toolbox key and select either CAS Solve or App Solve or do I simply enter an equation?
xTheta provides "A" in this mode
OPTION 2
-Set Up HOME >> APP >> FUNCTION >> ESC
xTheta provides "X" in this mode
-Tap CAS, CAS and FUNCTION displayed in title bar
xTheta provides "x" in this mode, I believe to be because CAS requires lower case VARs
-TOOLBOX >> CAS TAB >> SOLVE
OPTION 3
-Set Up >> HOME >> APP >> FUNCTION
TOOLBOX >> APP >> SOLVE >> SOLVE
Solve.SOLVE()
OPTION 4
TOOLBOX >> CAS >> SOLVE >> SOLVE
CAS.Solve()
I am thinking this is prone to syntax errors as the is "X" and not "x" as I think this
is a CAS setup that a lower case VAR is required.
There are so many solve modes for basic equations that I get lost in which one I should use.
(and I haven't even covered the use of solver apps which I think should be straightforward as they are dedicated to a specific type of solve operation, Eg Triangle or Finance . . .
I guess what I am asking is how do I know when solve will work without a syntax error
and does it truly make a diff what xTheta provides? I understand the concept that xTheta provides the VAR based on the current mode the calculator is in.
Some of my frustration is that I am transferring from a TI NSpire CAS which adjusts the calculation mode automatically between numeric and symbolic resulting in fewer syntax errors (for me that is).
Any advice you could offer would be appreciated.
I have asked this question previously and the answer is that CAS is for symbolic and non-CAS is for numeric. My understanding of this is:
Use numeric when you want an exact answer, Eg x = -1
Use CAS when you expect an approximation or an equation as an answer:
x=2/3 or x= x-4
Is there a setting to have the Prime go into an auto mode when it comes to selecting the calculation mode it uses?
Thanks in Advance
-Tim C.
