07-17-2014, 06:51 PM
'been looking around the 41 Swap Disk programs and wonder if anybody has made an inventory of some sort for all those hundreds of routines. Mind you, it's a formidable jigsaw puzzle to attempt without any other guidance that the program listings...
The collection seems to have several sources, but it's interesting to see how many are in french, almost as if it was a main source for them. There sure must be some rhyme & reason amongst all that apparent chaos...
The HELP41 routine lists the name "M. Cracknell" as the compiler of the collection, is he still around perhaps?
FWIW, I've dome some sorting and grouping of the programs that I'll post shortly - also was intrigued by a seemingly intended collection of routines dealing with MCODE assembly and dis-assembly (yes, you heard right: in FOCAL!). Remarkable attempt, but very difficult to pierce them all together without instructions...
In case you don't believe it, take a look at the attached MOD file for V41 - straight port of the routines.
Any info would be great.
Cheers,
'AM
Cheers,
'AM
