Volks!
Today I got a HP 82166C HP-IL Kit and wanted to check its content.
I have some of the HP 82166A HP-IL Converter Prototyping Kits and some of the HP 82166C HP-IL Interface Kits but they all have different contents. Does someone has a full sett of these two boxes or is there a list, what belongs to which box?
Matthias
(06-06-2022 07:28 PM)HP-Collection Wrote: [ -> ]Volks!
Matthias
82166A Kit
2x 82166A HP-IL Converters
2x 82167A HP-IL 0.5m Cables
2x GPIO connectors
1x 82166-60013 HP-IL Interfacing Board
1x 82166-90002 HP-IL Converter Technical Manual
1x 82165-90012 HP-IL Converter Manual Supplement
82166B Kit
10x 82166A HP-IL Converters
82166C Kit
Manuals & Softwares
1x 82166-90020 The HP-IL Interface Kit, Technical Guide
1x 82166-90016 The HP-IL Integrated Circuit, User's Manual
1x 82166-90017 The HP-IL Interface Specification
1x 82166-90013 Caution Card
1x 5955-9425 The HP-IL System, Book, ISBN: 0-931988-77-2
1x 82166-90002 HP-IL Converter, Technical Manual
1x 82165-90012 HP-IL Converter, Manual Supplement
2x 5061-5271 HP-41 HP-IL Development Module
1x 00041-90449 HP-41 HP-IL Development Module, Owner's Manual
1x 00075-90122 HP-75 I/O Utilities, Manual
1x 00075-12022 HP-75 I/O Utilities, Magnetic Cards
1x 00075-90144 HP-75 RIOWIO, Instruction Card
1x 00075-12025 HP-75 RIOWIO, Magnetic Cards
Electronic Parts Early Kits (before mid 1983)
8x 0683-1535 Resistor 15 kilohms 5% 25 watt
8x 0698-3446 Resistor 383 ohms 1% .125 watt
8x 0160-4292 Capacitor 330 picofarad 5%
8x 1902-0953 Xener Diode 6.2 volt 1N753A
8x 1902-0970 Xener Diode 33 volt 1N973B
Electronic Parts Later Kits (after mid 1983)
4x 1810-0651 HP-IL Hybrid Network
Common Parts (Early+Later kits)
4x 0160-0576 Capacitor 0.1 microfarad
4x 0180-3135 Capacitor 10 microfarad
4x 0160-4800 Capacitor 120 picofarad 5%
4x 9100-1631 Inductor 56 microhenry 5%
2x 0410-1305 Crystal 4 megahertz
8x 0624-0626 Screw 2-28 self-tapping
8x 3050-0626 Washer flat
4x 0950-0852 HP-IL Panel Receptacle
4x 9100-4226 HP-IL Pulse Transformer
4x ILB3-0003 HP-IL integrated circuit
2x 1820-2810 Microprocessor IC
1x 9311-4320 82166C HP-IL Interface Kit Box
Click on
View a Printable Version to get a printable listing
PS: it took me several edit/version to get the correct list
Edit: removed 82166-90024 Firmware Design for HP-IL Devices, Application Note from kit listing.
(06-07-2022 12:17 AM)Sylvain Cote Wrote: [ -> ]1x 82166-90024 Firmware Design for HP-IL Devices, Application Note
Are you sure this application note was included in the 82166C kit? I don't remember it was.
I still have all the 82166C kit original documentation, but the application note only as a photocopy, that I probably got later.
J-F
Hi Matthias,
I found a leaflet from back then, hopefully this helps.
DropBox has blocked my abilities to "Share Link" (not sure why) - so I dropped a note on your Museum with the list.
BTW, J-F is correct, the 90024 is not on the list
(06-07-2022 07:27 AM)J-F Garnier Wrote: [ -> ]Are you sure this application note was included in the 82166C kit? I don't remember it was.
(06-07-2022 08:54 AM)KimH Wrote: [ -> ]BTW, J-F is correct, the 90024 is not on the list
Yes, this is consistent with publish date (March 1984), more than one year after the kit.
BTW, when I started designing my first HP-IL device firmware (mid. 1984), I wasn't aware of this document, so wrote the software based on my own functional analysis. It was not as structured as the HP reference design, but was working well and my code of the time (with some later improvements) is still the base of the ILPer devices :-)
J-F
(06-07-2022 12:22 PM)J-F Garnier Wrote: [ -> ] (06-07-2022 07:27 AM)J-F Garnier Wrote: [ -> ]Are you sure this application note was included in the 82166C kit? I don't remember it was.
Thanks! I have removed the document from the kit list. (the HP 82166C kit I have is an early one)
