05-27-2022, 08:42 AM
Since I was thinking how to show the advantages of an HP41 to family members running around with ipads iphone macbooks xxGB RAM PCs (all laughing at me), and since I saw here a forum user showing old publications from "Ordinateur de poche", I have re-witten something very very serious because this is mandatory for having a good start in the day: a timer for cooking properly an egg.
The program is below; with comments.
HowTo..
Create a EGGA.TXT file in a PC
In the PC start the programm hp41uc.exe /t=EGGA.TXT /r /k for converting into a raw file
upload the created ERGGA.RAW file into V41 (menu in V41 "get user code")
Transfer the EGGA program into a virtual drive via ILPER (XEQ WRTP with EGGA in Alpha)
Connect your HP41 to the PC via pilbox and ILPER
In your HP41, makes XEQ READP (with EGGA in Alpha)
(or just create the program by hand direct into the HP41)
Now you can start it.
HowTo..
LBL "EGGA" ; EGGAlarm = timer for observing the cooking time of eggs with HP41
; Time module required
; use
; start to boil the water
; take your HP41; start the egg cooking timer
; with "XEQ" APLHA "EGGA" ALPHA
; Press key "1" (1 give short cooked egg;
; 2 give a soft cooked egg
; 3 makes a hard cooked egg)
; Press key "R/S" for confirming the above choice
; Press key "R/S" when you want to start the cooking
; the HP41 goes "OFF"
; keep the HP41 nearby your eating place for listening the alarm
; the HP41 wake up whith "TIMER ALARM" beeping several time when the
; eggs has to be taken out of the boiling water
; Press key "R/S", then the stopwatch stop
; the HP41 goes "OFF" after a "BEEP"
; change log
; 2022 05 27 creation based on program in french from
; Xavier de La Tullaye „ordinateur poche“ no 7
"1-SHELL"
AVIEW
"2-SOFT"
AVIEW
"3-HARD"
AVIEW
STOP
XEQ IND X
SETSW
"COOKING R/S"
AVIEW
STOP
RUNSW
OFF
BEEP
STOPSW
OFF
LBL 01
-.03
RTN
LBL 02
-.06
RTN
LBL 03
-.10
RTN
END
