05-18-2022, 05:52 PM
I was writing a long integer divider program, and was testing a value to see if it was working, and it was right, but it looks like the Prime was wrong, in CAS. I know this is very unlikely, and I hope someone will explain that it is down to the limited amount of information stored about the number, resulting in the wrong number being displayed after the place where E was.
I calculated 123456789123456789/127, in CAS mode. It gave the result 123456789123456789/127, then I pressed a b/c and it gave 9.72100701759E14 and I then pressed a b/c again, which resulted in the value that is not correct, which is 972100701759492.
I have just tried another 147258369147258369/127 and pressing a b/c twice again results in 1159514717694936, which is wrong by 11! The answer could have been as accurate as 1159514717694947.7874015748031496062992125984251968503937007874015748031496062992125984251968503937007874015748031496.
Is there any way to get full length division results in CAS, just like the long results from multiplication? Or a way to get more accurate results from CAS?
