Been a long time, anyway while learning on how to code using the
Python Programming Language and my first program is of cause the
good old "Profit on Pricing" calculations. This program I use the same
algorithm on my several HP programmable calculator found elsewhere here.
Here I'll share my code and this might be useful to some who also learn coding.
This link user can run this program and try out.
Enjoy !!
Link:
https://trinket.io/python/656c020f51?runOption=run
Gamo 5/2022
You can use this
Python to RPN - source code converter to translate your
Python code for the
HP-42S.
However, I had to adjust it a little bit to make it work:
LBL("Profit on Pricing")
p = 100 # Constant use for percentage
CST = PROMPT("Enter Cost : ")
SEL = PROMPT("Enter Price : ")
MUP = PROMPT("Enter Markup: ")
MAR = PROMPT("Enter Margin: ")
if CST and SEL != 0: # if both true
MAR = p * (SEL - CST) / SEL
MUP = p * (SEL - CST) / CST
if MAR == 0: # if true compute Margin
MAR = MUP / (1 + MUP / p)
# constant to plug into remaining formulas
q = 1 - MAR / p
if MUP == 0: # if true compute Markup
MUP = MAR / q
if CST == 0: # if true compute Cost
CST = SEL * q
if SEL == 0: # if true compute Price
SEL = CST / q
print("==================")
print("Cost = " "%1.2f"%(CST))
print("Price = " "%1.2f"%(SEL))
print("Markup = " "%1.1f"%(MUP)), ("%")
print("Margin = " "%1.1f"%(MAR)), ("%")
print("Profit = " "%1.2f"%(SEL - CST))
print("==========================================")
Some of the generated code can be simplified a bit.
For instance the following snippet:
… is translated to:
RCL "MAR" // MAR
0
XEQ 72 // compare, return bool
X≠0? // if true?
GTO 02 // if body
GTO 03 // resume
LBL 02 // if body
RCL "MUP" // MUP
1
RCL "MUP" // MUP
RCL 00 // p
STO "MAR" // MAR
LBL 03 // resume
But we can use instead:
RCL "MAR" // MAR
X≠0? // if set?
GTO 03 // resume
RCL "MUP" // MUP
1
RCL "MUP" // MUP
RCL 00 // p
STO "MAR" // MAR
LBL 03 // resume
However the generated code to print the results doesn't appear to work.
Still I hope that you have fun with
Python and your programs!
