I loaded up the Survey ROM after receiving this calculator 2 days ago, it shows in Active Modules, figured out how to get it to show up in CAT 2, but pressing R/S and Enter does not activate the program. The manual does not really help.
Any ideas on what I've missed?
Thx,
Dan
To run program MYPROG, you need to either assign it to a key or execute it via [XEQ]
To run it driectly:
[XEQ] [Alpha] MYROG [Alpha]
To Assign it to the [LOG] key:
[shift] [ASN] [Alpha] MYPROG [Alpha] [LOG]
Then, after making sure user is ON (press USER toggle until you see USER annunciator), just press the [LOG] key and MYPROG will run.
Running directly from the CAT-2 listing is not supported by the native 41 OS, but it is possible via some of the more exotic modules.
hth
Thanks, Bob.... that was the answer I was looking for.
Dan
