Anyone know the CASIO HQ-31?
It seems to be a very basic calculator with a time/calendar function.
But i don't know how to set the date or time on this device, and i find no manual online
for it.
attachment=10638]
I think this should work:
HHMM ADJ/SET for AM
HHMM. ADJ/SET for PM
ADJ/SET to correct the seconds
YYMMDD ADJ/SET if year<2000
YYYYMMDD ADJ/SET if year>1999
(04-24-2022 12:55 PM)xerxes Wrote: [ -> ]I think this should work:
HHMM ADJ/SET for AM
Wow!
It worked!
I managed to set both time and date!
Thanks a lot!
But, there is no 24 hour clock i assume? Just AM or PM 12 hour clock?
I must be stupid, but how do i set the alarm?
Yes, there is no 24 hour mode.
Does this work:
slide switch right, then HHMM ALARM
slide switch left: alarm on
slide switch center: alarm off
(04-24-2022 01:47 PM)xerxes Wrote: [ -> ]Does this work:
Thank you again, it worked out just fine!
Now i can set the alarm also
Very nice. I've also 2 calculators of that time in use (FX-8100 and EL-410).
Is it accurately showing dates on the calendar past 1999? I.e., can you enter 2022 and it's correct?
(04-26-2022 03:47 PM)bbergman Wrote: [ -> ]Is it accurately showing dates on the calendar past 1999? I.e., can you enter 2022 and it's correct?
The date seems working past 1999, i just set 22-04-26, and its showing up correct.
But i dont know about the calendar in the display, how is it supposed to work?
edit: for me in Sweden we use yy-mm-dd format, i.e todays date is 22-04-26, and it seems to work
on the HQ-31.
(04-26-2022 04:54 PM)Dan C Wrote: [ -> ]But i dont know about the calendar in the display, how is it supposed to work?
edit: for me in Sweden we use yy-mm-dd format, i.e todays date is 22-04-26, and it seems to work on the HQ-31.
Yes, that's what I was wondering. I'm assuming the little calendar has a box around the current day or something. Just curious.
BTW, I lived in Lulea for a while, love Sweden!
(04-26-2022 05:09 PM)bbergman Wrote: [ -> ]Yes, that's what I was wondering. I'm assuming the little calendar has a box around the current day or something. Just curious.
Hmm, then i wonder if the calendar is working.
Now when i have set the date to 22-04-26, the column marked in the calendar is 2,9,16,23,30.
And these must be the days in the month?
Wow! You know Sweden then! LuleƄ, thats a cold place in the north of Sweden with lots of snow!
(04-26-2022 04:54 PM)Dan C Wrote: [ -> ]edit: for me in Sweden we use yy-mm-dd format, i.e todays date is 22-04-26, and it seems to work
on the HQ-31.
In the U.S, yyyy-mm-dd is called the ISO date.
I have been using that exclusively* for a while now,
it makes the most sense to me.
* except when a different format is called out, such as in government forms. B^(
(04-26-2022 05:29 PM)Dan C Wrote: [ -> ]Now when i have set the date to 22-04-26, the column marked in the calendar is 2,9,16,23,30.
The marked column should show the sundays, but I assume that you have set the date to April 1922. Have you tried to set the date as "20220427"?
(04-27-2022 05:41 PM)xerxes Wrote: [ -> ] (04-26-2022 05:29 PM)Dan C Wrote: [ -> ]Now when i have set the date to 22-04-26, the column marked in the calendar is 2,9,16,23,30.
Yes, i have tried to set the date as 20220427, but the machine does not accept this format.
It only accept 220427, and then "adj/set" button.
It seems Casio never thought anybody would use this machine after year 1999, and therefor not did it millennium ready. After all, it must be a machine from mid 70ths or early 80ths i assume.
But i like the HQ-31 anyway, and the clock and alarm works at least!
(04-28-2022 06:09 PM)Dan C Wrote: [ -> ]It seems Casio never thought anybody would use this machine after year 1999, and therefor not did it millennium ready. After all, it must be a machine from mid 70ths or early 80ths i assume.
Watching a video yesterday about a 2002 Toyota Avalon where the clock/calendar built into the central display would not go past 2017 or 2018. It was 'Y2K compliant' but they just thought nobody would use it for more than 15-16 years. I have to wonder how many bits they saved with that decision...
(04-28-2022 05:50 PM)Dan C Wrote: [ -> ]Yes, i have tried to set the date as 20220427, but the machine does not accept this format.
Some Casio and Sharp calculators of that time accept the long format. In case of HQ-31 I would use a simple workaround: "year-28" or in 6 years "year-56" to have the correct display of the sundays.
(04-28-2022 07:44 PM)xerxes Wrote: [ -> ]Some Casio and Sharp calculators of that time accept the long format. In case of HQ-31 I would use a simple workaround: "year-28" or in 6 years "year-56" to have the correct display of the sundays.
Thanks for the input!, but i dont know how to do this on the HQ-31?
Just set the date to "940506" for today, to have the correct representation of the sundays.
(05-06-2022 04:26 PM)xerxes Wrote: [ -> ]Just set the date to "940506" for today, to have the correct representation of the sundays.
Thanks! i will try it.
I'm very impressed of the clock in my HQ-31!
I did set the time and date back in april this year, and still the time is almost spot on!
One strange thing is that the date is also correct, ie 22-09-22 today, but the sundays in the calender is off.
So, if i have set the year to 1922 instead of 2022, how can the date be correct?
EDIT: Forget that i wrote above! Of course the DATE is correct, whatever year i set
Only the DAYS name differs.
