04-10-2022, 07:25 PM
The Simulator
This Python program simulates an HP calculator:
The stack and the use of registers is implemented.
Also the most common functions are provided.
Writing Programs
It is straight forward to write a program using these functions.
Area of a Circle
This program calculates the area of a circle based on the radius \(r\):
A = \pi r^2
Quadratic Equation
This program calculates the solution of the quadratic equation based on the coefficients \(a\), \(b\) and \(c\):
a x^2 + b x + c = 0
Numeric Evaluation
Import the math Library
If we want to analyze the numeric values we import the math library:
X: 0.000000000000e+00 Y: 0.000000000000e+00 Z: 0.000000000000e+00 T: 0.000000000000e+00 L: 0.000000000000e+00 : CLST
Area of a Circle
X: 1.600000000000e+01 Y: 0.000000000000e+00 Z: 0.000000000000e+00 T: 0.000000000000e+00 L: 4.000000000000e+00 : XT2
X: 3.141592653590e+00 Y: 1.600000000000e+01 Z: 0.000000000000e+00 T: 0.000000000000e+00 L: 4.000000000000e+00 : PI
X: 5.026548245744e+01 Y: 0.000000000000e+00 Z: 0.000000000000e+00 T: 0.000000000000e+00 L: 3.141592653590e+00 : MUL
Quadratic Equation
X: -1.000000000000e+00 Y: -1.000000000000e+00 Z: -1.000000000000e+00 T: 1.000000000000e+00 L: 0.000000000000e+00 : DUP
X: 1.000000000000e+00 Y: -1.000000000000e+00 Z: -1.000000000000e+00 T: -1.000000000000e+00 L: 0.000000000000e+00 : RUP
X: -1.000000000000e+00 Y: -1.000000000000e+00 Z: -1.000000000000e+00 T: -1.000000000000e+00 L: 1.000000000000e+00 : DIV
X: -1.000000000000e+00 Y: -1.000000000000e+00 Z: -1.000000000000e+00 T: -1.000000000000e+00 L: 1.000000000000e+00 : RUP
X: 1.000000000000e+00 Y: -1.000000000000e+00 Z: -1.000000000000e+00 T: -1.000000000000e+00 L: 1.000000000000e+00 : LASTX
X: -2.000000000000e+00 Y: -1.000000000000e+00 Z: -1.000000000000e+00 T: -1.000000000000e+00 L: 1.000000000000e+00 : number -2
X: 5.000000000000e-01 Y: -1.000000000000e+00 Z: -1.000000000000e+00 T: -1.000000000000e+00 L: -2.000000000000e+00 : DIV
X: 5.000000000000e-01 Y: 5.000000000000e-01 Z: -1.000000000000e+00 T: -1.000000000000e+00 L: -2.000000000000e+00 : DUP
X: 5.000000000000e-01 Y: 5.000000000000e-01 Z: 5.000000000000e-01 T: -1.000000000000e+00 L: -2.000000000000e+00 : DUP
X: 2.500000000000e-01 Y: 5.000000000000e-01 Z: 5.000000000000e-01 T: -1.000000000000e+00 L: 5.000000000000e-01 : XT2
X: -1.000000000000e+00 Y: 2.500000000000e-01 Z: 5.000000000000e-01 T: 5.000000000000e-01 L: 5.000000000000e-01 : RUP
X: 1.250000000000e+00 Y: 5.000000000000e-01 Z: 5.000000000000e-01 T: 5.000000000000e-01 L: -1.000000000000e+00 : SUB
X: 1.118033988750e+00 Y: 5.000000000000e-01 Z: 5.000000000000e-01 T: 5.000000000000e-01 L: 1.250000000000e+00 : SQRT
X: -6.180339887499e-01 Y: 5.000000000000e-01 Z: 5.000000000000e-01 T: 5.000000000000e-01 L: 1.118033988750e+00 : SUB
X: 5.000000000000e-01 Y: -6.180339887499e-01 Z: 5.000000000000e-01 T: 5.000000000000e-01 L: 1.118033988750e+00 : SWAP
X: 1.118033988750e+00 Y: 5.000000000000e-01 Z: -6.180339887499e-01 T: 5.000000000000e-01 L: 1.118033988750e+00 : LASTX
X: 1.618033988750e+00 Y: -6.180339887499e-01 Z: 5.000000000000e-01 T: 5.000000000000e-01 L: 1.118033988750e+00 : ADD
Symbolic Evaluation
Import the sympy Library
If we want to analyze the symbolic values we import the sympy library:
X: 0 Y: 0 Z: 0 T: 0 L: 0 : CLST
Area of a Circle
X: r**2 Y: 0 Z: 0 T: 0 L: r : XT2
X: pi Y: r**2 Z: 0 T: 0 L: r : PI
X: pi*r**2 Y: 0 Z: 0 T: 0 L: pi : MUL
Quadratic Equation
X: c Y: c Z: b T: a L: 0 : DUP
X: a Y: c Z: c T: b L: 0 : RUP
X: c/a Y: c Z: b T: b L: a : DIV
X: b Y: c/a Z: c T: b L: a : RUP
X: a Y: b Z: c/a T: c L: a : LASTX
X: b/a Y: c/a Z: c T: c L: a : DIV
X: -2 Y: b/a Z: c/a T: c L: a : number -2
X: -b/(2*a) Y: c/a Z: c T: c L: -2 : DIV
X: -b/(2*a) Y: -b/(2*a) Z: c/a T: c L: -2 : DUP
X: -b/(2*a) Y: -b/(2*a) Z: -b/(2*a) T: c/a L: -2 : DUP
X: b**2/(4*a**2) Y: -b/(2*a) Z: -b/(2*a) T: c/a L: -b/(2*a) : XT2
X: c/a Y: b**2/(4*a**2) Z: -b/(2*a) T: -b/(2*a) L: -b/(2*a) : RUP
X: -c/a + b**2/(4*a**2) Y: -b/(2*a) Z: -b/(2*a) T: -b/(2*a) L: c/a : SUB
X: sqrt(-c/a + b**2/(4*a**2)) Y: -b/(2*a) Z: -b/(2*a) T: -b/(2*a) L: -c/a + b**2/(4*a**2) : SQRT
X: -sqrt(-c/a + b**2/(4*a**2)) - b/(2*a) Y: -b/(2*a) Z: -b/(2*a) T: -b/(2*a) L: sqrt(-c/a + b**2/(4*a**2)) : SUB
X: -b/(2*a) Y: -sqrt(-c/a + b**2/(4*a**2)) - b/(2*a) Z: -b/(2*a) T: -b/(2*a) L: sqrt(-c/a + b**2/(4*a**2)) : SWAP
X: sqrt(-c/a + b**2/(4*a**2)) Y: -b/(2*a) Z: -sqrt(-c/a + b**2/(4*a**2)) - b/(2*a) T: -b/(2*a) L: sqrt(-c/a + b**2/(4*a**2)) : LASTX
X: sqrt(-c/a + b**2/(4*a**2)) - b/(2*a) Y: -sqrt(-c/a + b**2/(4*a**2)) - b/(2*a) Z: -b/(2*a) T: -b/(2*a) L: sqrt(-c/a + b**2/(4*a**2)) : ADD
Ad Hoc Calculations
We can also do some ad hoc calculations:
X: atan(x) Y: 0 Z: 0 T: 0 L: x : ATAN
X: x/sqrt(x**2 + 1) Y: 0 Z: 0 T: 0 L: atan(x) : SIN
LaTeX Support
These results can be transformed into LaTeX:
\frac{x}{\sqrt{x^{2} + 1}}
If we want all results printed in LaTeX we can modify the fmt function:
Complex Numbers
I haven't tried this yet, but we could import the functions from the cmath library.
However, the formatting will likely require some adjustments.
Caveat
Still, I hope this might be useful.
X, Y, Z, T, L = [0] * 5
R = [0] * 10
SYMBOLIC = None
def trace(operation):
def fmt(s):
return str(s)
def wrapper(*args):
operation(*args)
params = ' '.join(map(str, args))
if SYMBOLIC:
print((
f"X: {fmt(X):<50s} "
f"Y: {fmt(Y):<50s} "
f"Z: {fmt(Z):<50s} "
f"T: {fmt(T):<50s} "
f"L: {fmt(L):<50s} "
f": {operation.__name__} {params}"
else:
print((
f"X: {X:< 20.12e} "
f"Y: {Y:< 20.12e} "
f"Z: {Z:< 20.12e} "
f"T: {T:< 20.12e} "
f"L: {L:< 20.12e} "
return wrapper
# operations
@trace
def CHS(): # +/-
global X, Y, Z, T, L
X = -X
@trace
def ADD(): # +
X, Y, Z, L = Y + X, Z, T, X
@trace
def SUB(): # -
X, Y, Z, L = Y - X, Z, T, X
@trace
def MUL(): # *
X, Y, Z, L = Y * X, Z, T, X
@trace
def DIV(): # /
X, Y, Z, L = Y / X, Z, T, X
@trace
def MOD():
X, Y, Z, L = Y % X, Z, T, X
@trace
def YTX(): # Y^X
X, Y, Z, L = Y ** X, Z, T, X
# functions
@trace
def RECIPROCAL(): # 1/X
X, L = 1 / X, X
@trace
def FACT(): # X!
X, L = factorial(X), X
@trace
def XT2(): # X^2
X, L = X ** 2, X
@trace
def SQRT():
X, L = sqrt(X), X
@trace
def EXP(): # E^X
X, L = exp(X), X
@trace
def LN():
X, L = log(X), X
@trace
def TENTX(): # 10^X
X, L = 10 ** X, X
@trace
def LOG():
X, L = log(X) / log(10), X
# trigonometry
@trace
def PI():
X, Y, Z, T = pi, X, Y, Z
@trace
def SIN():
X, L = sin(X), X
@trace
def ASIN():
X, L = asin(X), X
@trace
def COS():
X, L = cos(X), X
@trace
def ACOS():
X, L = acos(X), X
@trace
def TAN():
X, L = tan(X), X
@trace
def ATAN():
X, L = atan(X), X
# hyperbolic
@trace
def SINH():
X, L = sinh(X), X
@trace
def ASINH():
X, L = asinh(X), X
@trace
def COSH():
X, L = cosh(X), X
@trace
def ACOSH():
X, L = acosh(X), X
@trace
def TANH():
X, L = tanh(X), X
@trace
def ATANH():
X, L = atanh(X), X
# stack
@trace
def number(n):
X, Y, Z, T = n, X, Y, Z
@trace
def SWAP(): # X<>Y
X, Y = Y, X
@trace
def DUP(): # ENTER
Y, Z, T = X, Y, Z
@trace
def RUP(): # R^
X, Y, Z, T = T, X, Y, Z
@trace
def RDN(): # Rv
X, Y, Z, T = Y, Z, T, X
@trace
def LASTX():
X, Y, Z, T = L, X, Y, Z
@trace
def CLST():
# register
@trace
def CLRG():
R = [0] * 10
@trace
def STO(n):
R[n] = X
@trace
def RCL(n):
X, Y, Z, T = R[n], X, Y, Z
Writing Programs
Area of a Circle
A = \pi r^2
def area(r):
X = r
XT2() # X^2
PI() # PI
MUL() # *
Quadratic Equation
a x^2 + b x + c = 0
def quadratic_equation(a, b, c):
X, Y, Z = c, b, a
DUP() # ENTER
RUP() # R^
DIV() # /
RUP() # R^
LASTX() # LASTX
DIV() # /
number(-2) # -2
DIV() # /
DUP() # ENTER
DUP() # ENTER
XT2() # X^2
RUP() # R^
SUB() # -
SQRT() # SQRT
SUB() # -
SWAP() # X<>Y
LASTX() # LASTX
ADD() # +
Numeric Evaluation
from math import (
pi,
sqrt,
factorial,
exp,
log,
sin,
asin,
cos,
acos,
tan,
atan,
sinh,
asinh,
cosh,
acosh,
tanh,
atanh,
SYMBOLIC = False
CLST()
Area of a Circle
r = 4
area(r)
Quadratic Equation
a, b, c = 1, -1, -1
Symbolic Evaluation
from sympy import (
pi,
sqrt,
factorial,
exp,
log,
sin,
asin,
cos,
acos,
tan,
atan,
sinh,
asinh,
cosh,
acosh,
tanh,
atanh,
symbols,
expand,
simplify,
latex,
SYMBOLIC = True
CLST()
Area of a Circle
r = symbols("r")
area(r)
Quadratic Equation
a, b, c = symbols("a b c")
Ad Hoc Calculations
x = symbols("x")
CLST()
X = x
ATAN()
SIN()
LaTeX Support
print(latex(X))
def fmt(s):
return latex(s)
Complex Numbers
Caveat
- LBL and GTO are missing, but we can simulate that with the Python control structures
- stack lift isn't handled, but that's not usually a problem in programs
- probably something is still missing
