Am I using GETKEY wrong here? Why does each keypress not get registered?
EXPORT Keytest
LOCAL K:=0;
LOCAL X:=0;
LOCAL Y:=0;
RECT_P();
REPEAT
K:=GETKEY;
IF K>(-1) THEN
TEXTOUT_P(K,X,Y);
X:=X+16;
IF X>300 THEN
Y:=Y+20;
X:=0;
UNTIL ISKEYDOWN(4)=1;
I found WAIT(-1) was more suitable for most UI purposes. The code below is an example to check for keys and touch screen input, hope it helps.
#pragma mode( separator(.,;) integer(h32) )
// support routines
ResetTExit();
GetMK_in();
FlushKeysMouse();
ClearMouse();
// global variables
TExit:=2; // number of minutes before auto exit
TExit_count; // timeout tracker
MK_in,MK_mx,MK_my; // input variable and touch input x and y coordinates
EXPORT TESTUI()
LOCAL my_str:="",exit_cond:=0;
TExit_count:=0; // initialize auto exit counter
REPEAT
RECT_P(); // clear the screen
TEXTOUT_P("TESTUI",G0,0,0); // some static text
TEXTOUT_P(my_str,G0,0,50);
DRAWMENU("","","","","Cancel","OK"); // basic menu
GetMK_in(); // get input
IF TYPE(MK_in)==0 THEN // keyboard input
IF MK_in==-1 THEN // timeout after 60 seconds
TExit_count:=TExit_count+1; // increment the exit counter
my_str:="Exit counter is at " + STRING(TExit_count);
ELSE
ResetTExit(); // input was provided so clear the exit counter
CASE
IF MK_in==19 THEN // backspace
MSGBOX("Exit condition met");
exit_cond:=1;
IF MK_in==30 THEN // ENTER
my_str:="ENTER was pressed";
IF MK_in==400 THEN // timed out
MSGBOX("Timed out");
exit_cond:=1;
DEFAULT
my_str:="Key " + STRING(MK_in) + " was pressed";
ELSE // touch input
CASE
IF MK_my>219 THEN // menu
CASE
IF 265>MK_mx>212 THEN // Cancel
exit_cond:=1;
IF MK_mx>264 THEN // OK
my_str:="OK menu button was touched";
DEFAULT
my_str:="Menu area left of cancel was touched";
DEFAULT // above menu area
my_str:="X: " + STRING(B→R(MK_mx)) + " Y: " + STRING(B→R(MK_my));
UNTIL exit_cond;
ResetTExit()
IF MK_in<>400 THEN
TExit_count:=0;
GetMK_in()
IF TExit_count==TExit THEN
MK_in:=400;
ELSE
REPEAT
IFERR MK_in:=WAIT(-1); THEN
MK_in:=4;
FlushKeysMouse();
UNTIL TYPE(MK_in)==0 OR IFTE(SIZE(MK_in)>1,MK_in(1)==3,0);
ClearMouse();
IF TYPE(MK_in)==6 THEN // list
MK_mx:=MK_in(2);
MK_my:=MK_in(3);
TExit_count:=0;
// get all keys and mouse events out of the system
FlushKeysMouse()
LOCAL j,ksum;
REPEAT
ksum:=0;
FOR j FROM 0 TO 50 DO
ksum:=ksum+ISKEYDOWN(j);
UNTIL ksum==0;
ClearMouse();
ClearMouse()
LOCAL m;
REPEAT
m:=MOUSE();
UNTIL SIZE(m(1))==0;
That is a brilliant program. Thanks for sharing it.
