I remember on the previous update I created a program that could convert degrees to radians and radians to degrees in maybe 1 or 2 keystrokes. Unfortunately, this program is no longer supported on my calculator. Rather than go through the units and do the tedious process of conversions. Is there a quicker and more effective method to do this. I remember the program being called D2R (Degrees to radians) and R2D (Radians to degrees).
(04-03-2022 06:39 PM)IsaiahG0701 Wrote: [ -> ]I remember on the previous update I created a program that could convert degrees to radians and radians to degrees in maybe 1 or 2 keystrokes. Unfortunately, this program is no longer supported on my calculator. Rather than go through the units and do the tedious process of conversions. Is there a quicker and more effective method to do this. I remember the program being called D2R (Degrees to radians) and R2D (Radians to degrees).
Bonjour
Voici ce que j'utilise, si ça peut vous aider.
Hello
Here's what I use, if it helps.
EXPORT D_R(d)
// Valeur en °
UVAL(CONVERT(d*1_deg,0_rad));
EXPORT R_D(r)
// Valeur en radians
UVAL(CONVERT(r*1_rad,0_deg));
Thank you so much! To start this would I go to the program tab?
(04-04-2022 05:42 AM)IsaiahG0701 Wrote: [ -> ]Thank you so much! To start this would I go to the program tab?
Oui vous allez dans l'onglet programme et vous créez un nouveau programme
puis vous entrez le code de ces 2 fonctions.
Yes you go to the program tab and create a new program
then you enter the code of these 2 functions.
As these programs are single line programs you can also define user functions using the Shift Define key (to the right of the Units key):
attachment=10500] [
attachment=10501]
Just use upper case letters for the variables : D and R instead of d and r.
Thank you so much! With these programs would I be able to simplify a decimal number into radian form? Like if I were to do 7.5*(4pi/135) and get .698. Would I be able to have this simplified into 2pi/9
(04-05-2022 04:42 PM)IsaiahG0701 Wrote: [ -> ]Would I be able to have this simplified into 2pi/9
Not with the programs above, but this:
EXPORT radexact(D)
CAS(EVAL("exact("+(D/π)+")"))*CAS(π);
program does do what you want.
(04-07-2022 12:36 PM)roadrunner Wrote: [ -> ] (04-05-2022 04:42 PM)IsaiahG0701 Wrote: [ -> ]Would I be able to have this simplified into 2pi/9
EXPORT radexact(D)
I know this is late to the game... but I tried the above radexact program and it gives a strange result. I entered 45 degrees and it returned 38,646,433/2,698,030*pi when I would have expected pi/4. Is that an issue with Prime or the results that I can expect, which are not correct.
Thanks to anyone still "listening" to this thread.
Bob
Python math library has radians() & degrees() functions. Remember beforehand do
