03-21-2022, 11:03 PM
I'm working on a program to generate characters for a role-playing game. I am having trouble with '+' used to append an item to a list:
When I run XGEN2, it stalls at INFORM in EDITX: the "$$EDITX" routine apparently fails to add CHRXCX as
the 5th element of the parameter-list. (CHRXCX has a value.) When I run "$$EDITX" on its own, however, it does add the list. And when I run EDITX on its own, it displays the input form correctly!
I am completely puzzled by this behaviour. Any ideas? Thanks in advance...
@ HP 48GX simulator
@ XGEN2 -- do the crunch for A/H Chaosium Runequest 3e characters
@ relevant parts of the program
INI$LOG @ initialize the logger function
" →X XGEN2" LOGGIT
@ append to LOG$S
LOAD$$ @ initialize data structures
CLFX
@ clear flags #1-#7
DO
SP$PICK
@ choose species from list, execute corresponding XX$$ routine setting species name, average characteristic values, mov stat, base age, and gender, and set flag #i if average characteristic #i is e.g. 10.5
UNTIL 1 ==
END
DUP 'CHRXCX' STO
@ save a copy of this vector, and pass a copy to next routines
BUMPX @ if flag #i set, add 1 to characteristic #i half the time
ADJX @ randomize each charax +2D4-4 -- definitely not canon!
EDITX @ edit the randomized set to taste
OBJ→ DROP @ put vector elements in stack, drop count from level 1 of strack
@ start a local variable block with values taken from stack
←str ←con ←siz ←int ←pow
←dex ←app ←mov ←age ←gnr
« ATTRS 'CHRXAT' STO @ calc attributes (hit points, strike rank,...), and save a vector thereof
SCMS 'CHRXSC' STO
@ calc Skills Category Modifiers and save a vector thereof
DO$PREXP 'CHRXPE' STO
@ handle previous experience for this character (not implemented)
» @ end local block
"X→ XGEN2" LOGGIT
LOG$S
@ show the log
'XGEN2' STO
@ $$EDITX -- set parameters for INFORM in EDITX
"EDIT CHARAX" @ title
{ { "STR:" "" 0 } { "CON:" "" 0 } { "SIZ:" "" 0 }
{ "INT:" "" 0 } { "POW:" "" 0 } { "DEX:" "" 0 }
{ "APP:" "" 0 } { "MOV:" "ms" 13 } { }
{ "age:" "" 0 } { }
{ "gnr:" "m,f,..." 2 } } @ field specs
{ 3 4 }
@ layout
{ } @ reset values
CHRXCX 1 →LIST +
@ append initial values as a list, as 5th item in the list
'$$EDITX' STO
@ EDITX --- run the input form, return a vector on the stack
" ->X EDITX" LOGGIT
DO
$$EDITX OBJ→ DROP
@ set the 5 values from $$EDITX on the stack for the input form
INFORM
UNTIL 1 ==
@ consume Boolean from stack
END @ return the edited values as a vector
" X-> EDITX" LOGGIT
'EDITX' STO
