Full Version: [Request] drawing a dinamic line
I'm trying to draw a diameter of a circle, and rotate by dragging your finger on the screen,
How to do a single line it looks? I tried but that rect(G2) after blit(G2) but erases the background
export Mes()
    LOCAL m,m1,m2,mx,my,mxi,myi,A;
  RECT(RGB(252,252,200));
        DIMGROB_P(G2,340,240,RGB(252,252,200,128));
        DIMGROB_P(G3,340,240,RGB(252,252,200,128));
      ARC_P(G3,160,105,85,0,360);
blit(G3);
WHILE MOUSE(1)≥0 DO END;
REPEAT
    REPEAT
        m:=MOUSE;
        m1:=B→R(m(1));
        m2:=B→R(m(2));
    UNTIL SIZE(m1)>0;
        mx:=m1(1);
        my:=m1(2);
        mxi:=m1(3);
        myi:=m1(4);
    if m1(5)==#2d then  A:=(mx-mxi); END;
    LINE_P(G2,161+85*COS(A),106+85*SIN(A),161-85*COS(A),106-85*SIN(A),RGB(0,0,255));
    TEXTOUT_P(A,G2,20,208,2,RGB(255,0,0));
  BLIT(G2);
UNTIL my>220 ;
For your example, fastest way is just redrawing the last line over with the background color.
(07-10-2014 07:41 PM)eried Wrote: [ -> ]For your example, fastest way is just redrawing the last line over with the background color.
the problem is that if redraw using blit (G3) in the last line, the screen flickers while dragging your finger with a very ugly effect.
Well, you can use G0 and/or a condition to avoid unnecessary redraws:
export Mes()
  LOCAL p1:=0,p2:=0,p3:=0,p4:=0,o1:=-1,o2:=-1,o3:=-1,o4:=-1;
  blit(G3);
REPEAT
  REPEAT
    m:=MOUSE;
    m1:=B→R(m(1));
    m2:=B→R(m(2));
  UNTIL SIZE(m1)>0;
  mx:=m1(1);
  my:=m1(2);
  mxi:=m1(3);
  myi:=m1(4);
  p1:=161+85*COS(A);
  p2:=106+85*SIN(A);
  p3:=161-85*COS(A);
  p4:=106-85*SIN(A);
  if p1<>o1 then
    LINE_P(G0,o1,o2,o3,o4,RGB(252,252,200));
    LINE_P(G0,p1,p2,p3,p4,RGB(0,0,255));
    o1:=p1;o2:=p2;o3:=p3;o4:=p4;
  end;
  //TEXTOUT_P(A,G0,20,208,2,RGB(255,0,0));
  //BLIT(G2);
UNTIL my>220 ;
thank you very much for the code, just what I needed
Habia intentado el volver a dibujar la recta de color del fondo pero me faltaba el condicional muchas gracias.
