12-21-2013, 06:41 PM
(12-21-2013 11:14 AM)Paul Dale Wrote: [ -> ]Option a for me. Less cluttered.
Pauli
SACRILEGE!
I want another shift key and more colours!
Pauli
(12-21-2013 10:25 PM)walter b Wrote: [ -> ](12-21-2013 06:41 PM)Geoff Quickfall Wrote: [ -> ]SACRILEGE!You don't remember how you voted, do you?
d;-)
(12-21-2013 11:07 PM)eri Wrote: [ -> ]Put the log functions under menu, but I think the menus should be under a shift key.From a design stance, you're right. Though the respective (blue) locations are all taken. And it would cost an extra keystroke to reach quite popular functions like e^x.
(12-21-2013 11:07 PM)eri Wrote: [ -> ]If there's no essential mapping of a top level key function then can it be made user's choice (program label)?What do you want to tell me? I've to guess:
(12-20-2013 06:04 PM)walter b Wrote: [ -> ]Hi all,
Until the threaded views become viable, please allow me to ask you for your preference comparing two (2) alternatives:
a) vs. b)
(12-22-2013 07:41 AM)walter b Wrote: [ -> ](12-21-2013 11:07 PM)eri Wrote: [ -> ]Put the log functions under menu, but I think the menus should be under a shift key.From a design stance, you're right. Though the respective (blue) locations are all taken. And it would cost an extra keystroke to reach quite popular functions like e^x.
You may reassign each and every label on the keyboard (except USER). Those user assignments will come to the front in user mode (sic!). There also will be a menu called "MyMenu" you may fill which will appear whenever no other menu is called (even outside of user mode). And you may define your own new menus.
Hope one of those statements may be an answer to what you wanted to ask.
d:-)
(12-22-2013 12:36 PM)Massimo Gnerucci Wrote: [ -> ]And what about this?Answer 2: Same reason as on the WP 34S (just a little reminder that double radix marks will set fraction mode as well).
Sooo niiiiice!
Oh, and why the double \(a\frac{b}{c}\) ?
(12-22-2013 08:14 PM)walter b Wrote: [ -> ](12-22-2013 12:36 PM)Massimo Gnerucci Wrote: [ -> ]And what about this?Answer 2: Same reason as on the WP 34S (just a little reminder that double radix marks will set fraction mode as well).
Sooo niiiiice!
Answer 1: IIRC, I explained already for the WP 34S why shifted labels shall be on one side of the primary function. De gustibus non est disputandum -- but as long as one design is more coherent than another, I tend to choose the coherent one.
d:-)
(12-22-2013 08:32 PM)Massimo Gnerucci Wrote: [ -> ]As far as I see it shifted functions should go on the top of the keyboard (cfr. your PC keyboard and older HP calcs), while putting side by side letters and blue shifted functions makes the bottom of a key a little crowded, or it is just me?As long as the lower part of each key is slanted, at least one shifted function will go there. As long as one shifted function goes there, why should the second shifted function of the same key go on its other side?? And as long as f comes before g in alphabet, f-shifted labels shall be closer to the primary ones than g-shifted labels.
(12-22-2013 08:32 PM)Massimo Gnerucci Wrote: [ -> ]I find the letters between the keys particularly disturbing.OK, if you know a better place not yet occupied, feel free to suggest it.
(12-22-2013 09:11 PM)walter b Wrote: [ -> ]Ciao Massimo,
Quote:(12-22-2013 08:32 PM)Massimo Gnerucci Wrote: [ -> ]I find the letters between the keys particularly disturbing.OK, if you know a better place not yet occupied, feel free to suggest it.
d:-)
(12-23-2013 03:49 AM)SlideRule Wrote: [ -> ]A
SlideRule
(12-23-2013 01:35 PM)BillCarter Wrote: [ -> ]I'll put the trigs/inverses, the logs/inverses, and sigma +/- on F1-F6 and label them accordingly for an uncluttered layout that will meet my needs >99% of the time.I'd recommend you put 'the trigs/inverses, the logs/inverses, and sigma +/-' into MyMenu so you'll see them all the time unless you called another menu. Then you don't have to label F1-F6.
(12-23-2013 11:28 PM)walter b Wrote: [ -> ]Don't forget two posters were clearly stating their will but were just ... ummh ... unable to find the voting box. Including them would turn the result - just by a nose again though. Develops like a handball score
(12-23-2013 11:41 PM)Marcel Samek Wrote: [ -> ](12-23-2013 11:28 PM)walter b Wrote: [ -> ]Don't forget two posters were clearly stating their will but were just ... ummh ... unable to find the voting box. Including them would turn the result - just by a nose again though. Develops like a handball score
Unable to find the voting box? How are they ever going to find something on a sub-menu? Those two need it spelled out on the keyboard. I call those two votes for b) by default.
(12-23-2013 10:48 PM)walter b Wrote: [ -> ]I'd recommend you put 'the trigs/inverses, the logs/inverses, and sigma +/-' into MyMenu so you'll see them all the time unless you called another menu. Then you don't have to label F1-F6.
