02-26-2022, 11:09 AM
Halley's Method
References
Formula
We start with Halley's Irrational Formula:
\(C_f(x)=x-\frac{2f(x)}{f{'}(x)+\sqrt{[f{'}(x)]^2-2f(x)f{''}(x)}}\)
However, we reduce the fraction with \(f{'}(x)\) to get:
\(C_f(x)=x-\frac{\frac{2f(x)}{f{'}(x)}}{1 + \sqrt{1 - \frac{2f(x)f{''}(x)}{[f{'}(x)]^2}}}\)
This allows us to reuse the following expression:
\(\frac{2f(x)}{f{'}(x)}\)
Also the expression avoids cancellation if \(f(x) \to 0\).
This is not the case for the alternative expression:
\(C_f(x)=x-\frac{1 - \sqrt{1 - \frac{2f(x)f{''}(x)}{[f{'}(x)]^2}}}{\frac{f{''}(x)}{f{'}(x)}}\)
Definitions
These definitions are used:
Registers
Intermediate results are kept in these registers:
\(\begin{matrix}
R_0 & h \\
R_1 & x \\
R_2 & y \\
R_3 & f^{-}_x \\
R_4 & f^{-}_y \\
R_5 & f_x \\
R_6 & f_y \\
I & \text{program} \\
\end{matrix}\)
Description
These are the steps of program A:
002 - 004: store \(z\)
005 - 062: calculate the next approximation
006 - 011: \(f(z - h)\)
012 - 016: \(f(z)\)
017 - 018: \(f(z + h)\)
019 - 029: \(f{'}\)
030 - 036: \(f{''}\)
037 - 040: \(2f \div f{'}\)
041 - 043: \(f{''} \div f{'}\)
045 - 053: \(dz\)
054 - 056: \(z = z - dz\)
057 - 062: loop until it is good enough
063 - 066: return \(z\)
067 - 075: calculate \(f(z + w) | w \in \{-h, 0, h\}\)
The programs B - E are examples from Valentin's article.
Example
The step-size h is stored in register 0, while the name/number of the program is specified in the variable I.
So let's assume we want to solve program B with step-size h = 10-4 and starting guess 2:
RCL MATRIX B
STO I
EEX 4 CHS
STO 0
2 A
Intermediate values of |dz| are displayed:
(( running ))
0.148589460
(( running ))
0.002695411
(( running ))
0.000000017
(( running ))
0.000000000
(( running ))
1.854105968
Should that annoy you just remove the PSE-command in line 058.
Programs
A: Halley's Method
B: Find a root of : \(x^x = \pi\)
C: Find all roots of: \(( 2 + 3i ) x^3 - (1 + 2i ) x^2 - ( 3 + 4i ) x - ( 6 + 8i ) = 0\)
D: Attempt to find a complex root of: \(x^3 - 6x - 2 = 0\)
E: Solve Leonardo di Pisa's equation: \(x^3 + 2 x^2 + 10 x - 20 = 0\)
References
- Halley's Irrational Formula
- Halley-Verfahren
- Halley's method
- HP Article VA031 - Boldly Going - Going Back to the Roots
- 35s - find roots of 3rd and higher order equations
- Solver for the HP-15C
Formula
Definitions
- \(z = x + i y\)
- \(f^{+} = f(z + h) = f^{+}_x + i f^{+}_y\)
- \(f^{-} = f(z - h) = f^{-}_x + i f^{-}_y\)
- \(f = f(z) = f_x + i f_y\)
- \(f{'} = f{'}(z) h \approx \frac{f^{+} - f^{-}}{2}\)
- \(f{''} = f{''}(z) h^2 \approx f^{+} - 2f + f^{-}\)
Registers
\(\begin{matrix}
R_0 & h \\
R_1 & x \\
R_2 & y \\
R_3 & f^{-}_x \\
R_4 & f^{-}_y \\
R_5 & f_x \\
R_6 & f_y \\
\end{matrix}\)
Description
012 - 016: \(f(z)\)
019 - 029: \(f{'}\)
045 - 053: \(dz\)
Example
RCL MATRIX B
STO I
EEX 4 CHS
STO 0
2 A
(( running ))
0.148589460
(( running ))
0.002695411
(( running ))
0.000000017
(( running ))
0.000000000
(( running ))
1.854105968
Programs
A: Halley's Method
001 { 42 21 11 } f LBL A
002 { 44 1 } STO 1
003 { 42 30 } f Re↔Im
004 { 44 2 } STO 2
005 { 42 21 0 } f LBL 0
006 { 45 0 } RCL 0
007 { 16 } CHS
008 { 32 1 } GSB 1
009 { 44 3 } STO 3
010 { 42 30 } f Re↔Im
011 { 44 4 } STO 4
012 { 0 } 0
013 { 32 1 } GSB 1
014 { 44 5 } STO 5
015 { 42 30 } f Re↔Im
016 { 44 6 } STO 6
017 { 45 0 } RCL 0
018 { 32 1 } GSB 1
019 { 36 } ENTER
020 { 36 } ENTER
021 { 45 3 } RCL 3
022 { 45 4 } RCL 4
023 { 42 25 } f I
024 { 40 } +
025 { 34 } x↔y
026 { 43 36 } g LSTx
027 { 30 } −
028 { 2 } 2
029 { 10 } ÷
030 { 34 } x↔y
031 { 45 5 } RCL 5
032 { 45 6 } RCL 6
033 { 42 25 } f I
034 { 36 } ENTER
035 { 40 } +
036 { 30 } −
037 { 1 } 1
038 { 43 36 } g LSTx
039 { 43 33 } g R⬆
040 { 10 } ÷
041 { 43 33 } g R⬆
042 { 43 36 } g LSTx
043 { 10 } ÷
044 { 34 } x↔y
045 { 20 } ×
046 { 43 36 } g LSTx
047 { 33 } R⬇
048 { 30 } −
049 { 11 } √x̅
050 { 40 } +
051 { 10 } ÷
052 { 45 0 } RCL 0
053 { 20 } ×
054 { 44 30 1 } STO − 1
055 { 42 30 } f Re↔Im
056 { 44 30 2 } STO − 2
057 { 43 16 } g ABS
058 { 42 31 } f PSE
059 { 45 0 } RCL 0
060 { 43 11 } g x²
061 { 43 30 8 } g TEST x<y
062 { 22 0 } GTO 0
063 { 45 1 } RCL 1
064 { 45 2 } RCL 2
065 { 42 25 } f I
066 { 43 32 } g RTN
067 { 42 21 1 } f LBL 1
068 { 45 1 } RCL 1
069 { 45 2 } RCL 2
070 { 42 25 } f I
071 { 40 } +
072 { 36 } ENTER
073 { 36 } ENTER
074 { 36 } ENTER
075 { 22 25 } GTO I
076 { 42 21 12 } f LBL B
077 { 14 } yˣ
078 { 43 26 } g π
079 { 30 } −
080 { 43 32 } g RTN
081 { 42 21 13 } f LBL C
082 { 2 } 2
083 { 36 } ENTER
084 { 3 } 3
085 { 42 25 } f I
086 { 20 } ×
087 { 1 } 1
088 { 36 } ENTER
089 { 2 } 2
090 { 42 25 } f I
091 { 30 } −
092 { 20 } ×
093 { 3 } 3
094 { 36 } ENTER
095 { 4 } 4
096 { 42 25 } f I
097 { 30 } −
098 { 20 } ×
099 { 6 } 6
100 { 36 } ENTER
101 { 8 } 8
102 { 42 25 } f I
103 { 30 } −
104 { 43 32 } g RTN
105 { 42 21 14 } f LBL D
106 { 43 11 } g x²
107 { 6 } 6
108 { 30 } −
109 { 20 } ×
110 { 2 } 2
111 { 30 } −
112 { 43 32 } g RTN
113 { 42 21 15 } f LBL E
114 { 2 } 2
115 { 40 } +
116 { 20 } ×
117 { 1 } 1
118 { 0 } 0
119 { 40 } +
120 { 20 } ×
121 { 2 } 2
122 { 0 } 0
123 { 30 } −
124 { 43 32 } g RTN
