02-25-2022, 01:20 AM
Bairstow's Method
Links
Wikipedia
MathWorld
Algorithm
We are looking for a quadratic factor T(x) of the polynomial P(x). In general there will be a linear remainder R(x) after the division:
\(P(x) = Q(x) \cdot T(x) + R(x)\)
\(P(x) = a_n x^n + a_{n-1} x^{n-1} + \cdots + a_2 x^2 + a_1 x + a_0\)
\(T(x) = x^2 + p x + q\)
\(Q(x) = b_n x^{n-2} + b_{n-1} x^{n-3} + \cdots + b_4 x^2 + b_3 x + b_2\)
\(R(x) = b_1 ( x + p ) + b_0\)
If we set \(b_{n+1}\equiv b_{n+2}\equiv 0\), then \(\forall k\leq n\):
\(b_k = a_k - b_{k+1} p - b_{k+2} q\)
The two coefficients of the remainder R(x) depend on p and q:
\(b_0 = b_0(p, q)\)
\(b_1 = b_1(p, q)\)
To make T(x) a factor of P(x) the remainder R(x) must vanish. Let's assume that we already have p and q close to the solution. We want to know how to change these values to get a better solution. Therefore we set the first order Taylor series expansion to 0:
\(b_0(p + \delta p, q + \delta q) \approx b_0(p, q) + \frac{\partial b_0}{\partial p} \delta p + \frac{\partial b_0}{\partial q} \delta q = 0\)
\(b_1(p + \delta p, q + \delta q) \approx b_1(p, q) + \frac{\partial b_1}{\partial p} \delta p + \frac{\partial b_1}{\partial q} \delta q = 0 \)
It turns out that the partial derivatives of \(b_k\) with respect to p and q can be calculated with a similar recurrence formula:
\(c_{k+1} = - \frac{\partial b_k}{\partial p}\)
\(c_{k+2} = - \frac{\partial b_k}{\partial q}\)
\(c_k = b_k - c_{k+1} p - c_{k+2} q\)
Thus we have to solve:
\(\begin{matrix}
c_1 \delta p + c_2 \delta q &= b_0 \\
c_2 \delta p + c_3 \delta q &= b_1
\end{matrix}\)
Using Linear Regression
We have to solve a 2-dimensional linear equation:
\(\begin{bmatrix}
c_1 & c_2 \\
c_2 & c_3
\end{bmatrix}\cdot\begin{bmatrix}
\delta p \\
\delta q
\end{bmatrix}=\begin{bmatrix}
b_0 \\
b_1
\end{bmatrix}\)
But since the matrix is symmetric we can use the built-in function L.R. for linear regression.
We know that the following equation is solved for A and B:
\(\begin{bmatrix}
\sum x^2 & \sum x \\
\sum x & n
A \\
B
\sum xy \\
\sum y
\end{bmatrix}\)
Cramer's Rule gives the solutions:
\(A=\frac{\begin{vmatrix}
\sum xy & \sum x \\
\sum y & n
\end{vmatrix}}{\begin{vmatrix}
\sum x & n
\end{vmatrix}}=\frac{n\sum xy-\sum x\sum y}{n\sum x^2-(\sum x)^2}\)
\(B=\frac{\begin{vmatrix}
\sum x^2 & \sum xy \\
\sum x & \sum y
\sum x & n
\end{vmatrix}}=\frac{\sum y\sum x^2-\sum x\sum xy}{n\sum x^2-(\sum x)^2}\)
For this to work we have to fill the registers R2 - R7 with the corresponding values of the equation:
\(\begin{matrix}
n & \rightarrow & R_2 \\
\sum x & \rightarrow & R_3 \\
\sum x^2 & \rightarrow & R_4 \\
\sum y & \rightarrow & R_5 \\
\sum y^2 & \rightarrow & R_6 \\
\sum xy & \rightarrow & R_7
\end{matrix}\)
This mapping leaves us with the following linear equation:
\(\begin{bmatrix}
R_4 & R_3 \\
R_3 & R_2
Y \\
X
R_7 \\
R_5
\end{bmatrix}\)
Example:
\(\begin{bmatrix}
2 & -3 \\
-3 & 5
2 \\
-3
13 \\
-21
\end{bmatrix}\)
CLEAR Σ
2 STO 4
-3 STO 3
5 STO 2
13 STO 7
-21 STO 5
L.R.
Y: 2
X: -3
Registers
\(\begin{matrix}
R_0 & p \\
R_1 & q \\
R_2 & c = c_j \\
R_3 & {c}′ = c_{j+1} \\
R_4 & {c}'' = c_{j+2} \\
R_5 & b = b_i \\
R_6 & \\
R_7 & {b}′ = b_{i+1} \\
R_8 & \text{index} = 9.fff \\
R_9 & a_n \\
R_{.0} & a_{n-1} \\
R_{.1} & a_{n-2} \\
R_{.2} & \cdots \\
R_{.3} & \cdots \\
\end{matrix}\)
Program
Description
Initialization k = n
Lines 002 - 004
\((b, {b}′, c, {c}′, {c}'') \leftarrow (0, 0, 0, 0, 0)\)
\(I \leftarrow\) index
Partial Derivatives
Lines 005 - 026
At the end of the loop \(b = b_0\) but \(c = c_1\)!
That's why the second division is performed before the first.
Iteration k+1 → k
Lines 006 - 015
\((c, {c}′, {c}'') \leftarrow (b - c p - {c}′ q, c, {c}′)\)
Lines 016 - 024
\((b, {b}′) \leftarrow (a_k - b p - {b}′ q, b)\)
Solve the linear equation
Line 027
The trick using linear regression only works since the matrix is symmetric.
\(\begin{bmatrix}
c & {c}' \\
{c}' & {c}''
\delta p \\
\delta q
b \\
{b}'
\end{bmatrix}\)
Find improved values for p and q
Lines 028 - 030
\(p \leftarrow p + \delta p\)
\(q \leftarrow q + \delta q\)
Stop Criterion
Lines 031 - 033
\(\left | (\delta p, \delta q) \right |< \varepsilon\)
\(\varepsilon = 10^{-n}\) if display is set to FIX n
Polynomial Division
Lines 035 - 057
We have to repeat the division here since we didn't keep \(b_k\) in lines 016 - 024.
Quadratic Solver
This program solves the quadratic equation: \(T(x)=x^2+px+q=0\)
Just be aware that this program can't find complex roots. Instead an Error 0 will be displayed.
However it's easy to find the complex solutions. Just use:
CHS
\(\sqrt{x}\)
The solutions then are: \(Y \pm iX\)
Example
\(P(x)=2x^5-9x^4+15x^3+65x^2-267x+234=0\)
Insert coefficients
Initialization
Alternatively use:
Run program
Conclusion
\(2x^5-9x^4+15x^3+65x^2-267x+234=\)
\((x^2+1.5x-4.5)(2x^3-12x^2+42x-52)\)
Solutions
For \(x^2+1.5x-4.5=0\):
\(x_1=1.5\)
\(x_2=-3\)
Initialize guess
Alternatively use:
Run program again
Conclusion
\(2x^3-12x^2+42x-52=\)
\((x^2-4x+13)(2x-4)\)
Solutions
For \(x^2-4x+13=0\):
\(x_3=2+3i\)
\(x_4=2-3i\)
For \(2x-4=0\):
\(x_5=2\)
Summary
Factors
\((x^2+1.5x-4.5)(x^2-4x+13)(2x-4)=\)
\((x-1.5)(x+3)(x^2-4x+13)2(x-2)=\)
\((2x-3)(x-2)(x+3)(x^2-4x+13)\)
Solutions
\(x_1=1.5\)
\(x_2=2\)
\(x_3=-3\)
\(x_4=2+3i\)
\(x_5=2-3i\)
Links
Wikipedia
MathWorld
Algorithm
\(b_0 = b_0(p, q)\)
\(b_1 = b_1(p, q)\)
\(\begin{matrix}
\end{matrix}\)
\(\begin{bmatrix}
c_1 & c_2 \\
c_2 & c_3
\delta p \\
\delta q
b_0 \\
b_1
\end{bmatrix}\)
\(\begin{bmatrix}
\sum x & n
A \\
B
\sum xy \\
\sum y
\end{bmatrix}\)
\sum xy & \sum x \\
\sum y & n
\sum x & n
\sum x & \sum y
\sum x & n
\(\begin{matrix}
\end{matrix}\)
\(\begin{bmatrix}
R_4 & R_3 \\
R_3 & R_2
Y \\
X
R_7 \\
R_5
\end{bmatrix}\)
Example:
\(\begin{bmatrix}
2 & -3 \\
-3 & 5
2 \\
-3
13 \\
-21
\end{bmatrix}\)
CLEAR Σ
2 STO 4
-3 STO 3
5 STO 2
13 STO 7
-21 STO 5
L.R.
Y: 2
X: -3
Registers
\(\begin{matrix}
R_0 & p \\
R_1 & q \\
R_2 & c = c_j \\
R_5 & b = b_i \\
R_6 & \\
R_9 & a_n \\
R_{.0} & a_{n-1} \\
R_{.1} & a_{n-2} \\
R_{.2} & \cdots \\
R_{.3} & \cdots \\
\end{matrix}\)
Program
001 { 42 21 11 } f LBL A
002 { 42 32 } f ∑
003 { 45 8 } RCL 8
004 { 44 25 } STO I
005 { 42 21 0 } f LBL 0
006 { 45 5 } RCL 5
007 { 45 3 } RCL 3
008 { 44 4 } STO 4
009 { 45 20 1 } RCL × 1
010 { 30 } −
011 { 45 2 } RCL 2
012 { 44 3 } STO 3
013 { 45 20 0 } RCL × 0
014 { 30 } −
015 { 44 2 } STO 2
016 { 45 24 } RCL (i)
017 { 45 7 } RCL 7
018 { 45 20 1 } RCL × 1
019 { 30 } −
020 { 45 5 } RCL 5
021 { 44 7 } STO 7
022 { 45 20 0 } RCL × 0
023 { 30 } −
024 { 44 5 } STO 5
025 { 42 6 25 } f ISG I
026 { 22 0 } GTO 0
027 { 42 49 } f L.R.
028 { 44 40 0 } STO + 0
029 { 34 } x↔y
030 { 44 40 1 } STO + 1
031 { 43 1 } g →P
032 { 43 34 } g RND
033 { 43 30 0 } g TEST x≠0
034 { 22 11 } GTO A
035 { 45 8 } RCL 8
036 { 2 } 2
037 { 26 } EEX
038 { 3 } 3
039 { 16 } CHS
040 { 30 } −
041 { 44 8 } STO 8
042 { 44 25 } STO I
043 { 0 } 0
044 { 36 } ENTER
045 { 42 21 1 } f LBL 1
046 { 45 24 } RCL (i)
047 { 45 1 } RCL 1
048 { 43 33 } g R⬆
049 { 20 } ×
050 { 30 } −
051 { 45 0 } RCL 0
052 { 43 33 } g R⬆
053 { 20 } ×
054 { 30 } −
055 { 44 24 } STO (i)
056 { 42 6 25 } f ISG I
057 { 22 1 } GTO 1
058 { 43 32 } g RTN
Description
Lines 002 - 004
Partial Derivatives
Lines 005 - 026
Iteration k+1 → k
Lines 006 - 015
Lines 016 - 024
Line 027
\(\begin{bmatrix}
c & {c}' \\
{c}' & {c}''
\delta p \\
\delta q
b \\
{b}'
\end{bmatrix}\)
Lines 028 - 030
Stop Criterion
Lines 031 - 033
Polynomial Division
Lines 035 - 057
Quadratic Solver
059 { 42 21 12 } f LBL B
060 { 45 0 } RCL 0
061 { 2 } 2
062 { 16 } CHS
063 { 10 } ÷
064 { 36 } ENTER
065 { 36 } ENTER
066 { 43 11 } g x²
067 { 45 30 1 } RCL − 1
068 { 11 } √x̅
069 { 30 } −
070 { 34 } x↔y
071 { 43 36 } g LSTx
072 { 40 } +
073 { 43 32 } g RTN
CHS
\(\sqrt{x}\)
Example
Insert coefficients
2 STO 9
-9 STO .0
15 STO .1
65 STO .2
-267 STO .3
234 STO .4
Initialization
9.014 STO 8
1 STO 0
STO 1
Alternatively use:
MATRIX 1
Run program
GSB A -52.0000
RCL 0 1.5000
RCL 1 -4.5000
RCL 9 2.0000
RCL .0 -12.0000
RCL .1 42.0000
RCL .2 -52.0000
GSB B 1.5000
x<>y -3.0000
Conclusion
Solutions
\(x_1=1.5\)
\(x_2=-3\)
Initialize guess
1 STO 0
STO 1
Alternatively use:
MATRIX 1
Run program again
GSB A -4.0000
RCL 0 -4.0000
RCL 1 13.0000
RCL 9 2.0000
RCL .0 -4.0000
GSB B Error 0
← -9.0000
CHS 9.0000
√x 3.0000
x<>y 2.0000
RCL .0 -4.0000
RCL 9 2.0000
÷ -2.0000
CHS 2.0000
Conclusion
Solutions
\(x_3=2+3i\)
\(x_4=2-3i\)
For \(2x-4=0\):
\(x_5=2\)
Summary
Factors
Solutions
\(x_1=1.5\)
\(x_2=2\)
\(x_3=-3\)
\(x_4=2+3i\)
\(x_5=2-3i\)
