English instruction manual for the Sharp PC-1260 and PC-1261 by Sharp 1984.
PC-1260-manual-EN.pdf
The instruction manual is also applicable to the Sharp PC-1262.
The manual includes instructions for the CE-125 and CE-126P peripherals.
Software Applications included:
Easy Simulation (ESP) Programs:
Golf Competition Scoring
Sub Total and Grand Total
Monthly Repayment Calculation
Discount Price List
Break-even Analysis
School Record Processing
BASIC programs:
Golf Competition Scoring Statistics
Typing Practice
Memory Check
Number of Days Computation
Histogram
Biorhythms
Average, Variance and Standard Deviation
Correlation Coefficient and Linear Regression
Simultaneous Equations
(02-18-2022 04:03 AM)Leonid Wrote: [ -> ] (02-17-2022 10:16 PM)robve Wrote: [ -> ]The instruction manual is also applicable to the Sharp PC-1262.
Thanks!
The PC-1262 is internally identical to the PC-1261. The appearance differs slightly:
Images from the
Pocket Computer Museum.
The PC-1260 (not shown) is the same as the PC-1261 but with only 4KB RAM instead of 10KB.
- Rob
Thanks Rob!!! We'll see if I can uncover any secrets that I hadn't found yet...
(02-17-2022 10:16 PM)robve Wrote: [ -> ]English instruction manual for the Sharp PC-1260 and PC-1261 by Sharp 1984.
Thank you so much! This is awesome, now, at last, there is an English manual for this great machine. And i dont need to learn German!
(02-18-2022 04:40 PM)Didier Lachieze Wrote: [ -> ] (02-18-2022 03:53 PM)Dan C Wrote: [ -> ]And i dont need to learn German!
nor French
Isn't English just a French dialect with a few German additions?
Günter
(02-18-2022 08:30 PM)Guenter Schink Wrote: [ -> ]Isn't English just a French dialect with a few German additions?
Günter
Exactly! But it's knowing which words are which that matters, as speaking with most will quickly show (that they too don't know...).
(02-18-2022 03:53 PM)Dan C Wrote: [ -> ] (02-17-2022 10:16 PM)robve Wrote: [ -> ]English instruction manual for the Sharp PC-1260 and PC-1261 by Sharp 1984.
Now i have downloaded the manual, and its much better then the German one i found!
Your is a real scan of the original, while the German one i found looked more typed in, not a scan.
Thanks again for a great work!
This is priceless. Thank you so much. Hopefully, I can find some spare time to start playing with my PC-126X again soon.
The PC-1261 and PC-1262 are identical, at least in their documented features.
However, I came across two bugs in a PC-1261 that I own that were fixed in the PC-1262 firmware updates. I don't know what ROM version my PC-1261 has, but these two one-liners demonstrate the bugs:
Program A:
10 "A" INPUT "#";X : END
Program B:
20 "B" WAIT : X=X : PRINT : END
RUN program A, e.g. with DEF-A. Type a number then ENTER. The PC-1261 incorrectly indicates a syntax error on line 10.
RUN program B with DEF-B. A prompt will appear when it should not. Then press +. Type in something. The cursor will appear to hang. Typing in something may actually affect the memory and destroy the stored programs (when programs are large enough to be observed to be affected). The X=X can be any assignment. On some other Sharp PC, this allows you to set an expression that you can then continue calculating with since it is in the hidden "answer" register. Same as PRINT with an expression that puts the numeric expression in the "answer" register when WAIT is used.
When you define an ESP formula in PRO mode:
#SQ=X*X
and then run program A in RUN mode, you can type SQ after the #. Then ENTER will bring up the formula. A nice hack, but that's not supposed to happen. It explains why a number is a syntax error (in ESP syntax after the #).
The fix for program A is to use INPUT "#",X with a comma to remove the # prompt when you type a number or when you press ENTER.
The fix for program B is to use PRINT "" with quotes, which does not trigger the bug.
- Rob
(02-18-2022 01:15 PM)robve Wrote: [ -> ] (02-18-2022 04:03 AM)Leonid Wrote: [ -> ]Thanks!
Images from the Pocket Computer Museum.
- Rob
I have a PC-1260 with 10KB. I think that the previous owner replaced the memory card.
