07-07-2014, 02:09 PM
It seems that if you use command line input on a program and the number format is set to have , delimiter every 3 digits you will get an error,
for Example
EXPORT Test (A,B,C) and if enter 5400,3000,2000, I get a Undefined Result Error.
It works fine if you use INPUT, I only get an error using the command line input and if I turn off the delimiter it works fine.
for Example
