01-13-2022, 02:07 AM
HP-11C program to calculate mod, GCD and LCM
mod is the modulo operation that returns the "Remainder" of a Division
GCD (Greatest Common Divisor) the largest positive integer that divides each of the integers
LCM (Least Common Multiple) is the smallest positive integer that is divisible by each integers
This program use "mod" function to calculate either GCD or LCM
For LCM calculation program must calculate the GCD first at which "mod" is also in use.
For faster calculation of the "Remainder" or "mod" and GCD
the algorithm in use is to be as simple as possible.
Remainder of a ÷ b
a ÷ b the result take the Integer Part x b - a then change sign
GCD algorithm use "mod" to help get faster result.
Calculate the GCD of a and b
Find Remainder of a ÷ b
Is Remainder 0
If No ( b store a and Remainder store b )
Keep repeating until Remainder is 0
The GCD is b
LCM algorithm use ( a x b ) ÷ GCD
Procedure:
▶ Input Integers a and b for a > b
▶ Input Integers a follow by Integer b
LBL A (Input Integer a)
LBL B (Input Integer b)
LBL C (Calculate Remainder)
LBL D (Calculate GCD)
LBL E (Calculate LCM)
Example: FIX 0
a = 112233
b = 321
112233 [A]
321 [B]
[C] Display Remainder Answer 204
[D] Display GCD Answer 3
[E] Display LCM Answer 12,008,931
Program:
Program Steps: 40
Remark:
This programs is not perfect so be aware of any bugs in this program if any.
Gamo 1/2022
Remainder of a ÷ b
Is Remainder 0
The GCD is b
Procedure:
Example: FIX 0
a = 112233
b = 321
112233 [A]
321 [B]
Program:
LBL A STO 1 RTN
LBL B STO 2 x STO 0 LSTx RTN
LBL C RCL 1 RCL 2 ÷ INT RCL 2 x RCL 1 - CHS STO 3 RTN
LBL D GSB C RCL 3 X=0 GTO 1 RCL 2 STO 1 RCL 3 STO 2 GTO D LBL 1 RCL 2 RTN
LBL E GSB D RCL 0 X<>Y ÷ RTN
Remark:
Gamo 1/2022
