12-25-2021, 01:36 PM
Hi, it has passed a few months since my last post.
I'm wondering is there a Chi table, Z table and T tables in the calculator from witch I can pull values ?
If there isn't is there a way to insert them and pull values.
2. Question I'm having a bit trouble again with the if statement.
The code is.
The issue is my q1 and q2 variables can be negative and that is a no go. If it's negative i have to add +180.
When I write
It correctly fixes the value of p1 if its negative. But I want to do that also if the q2 ends up being negative so I write:
In this case the result for q1(q3) is correct, but q2(q4) ends up being 0. And that is not correct.
What I want it to do is to:
Test if q1 is negative, it it is fix it by adding +180
Test if q2 is negative, if it is fix it by adding +180
If the q1 or q2 are positive don't touch their values, just print them. ( q1 and q2 are independent of each other)
Also I have forgot how or why. When I input the values into M1, M2 matrix ( default matrices that are in calculator).
Then I pull values like ( M1(1,1), M1(2,4) ) from matrices(M1,M2) to local variables a1,a2,b1,b2...
But it doesn't let me. ->I have to first store M1->A1, M2->A2
It doesn't let me for some reason. If i write in program M instead A ( matrix) to run the program i get an error.
My goal is to Input values to default matrix of calculator (M0-M9)
- Pull values from Matrix ( M0-M9) to local variable
Compute
A3:=(A2)^(-1)*A1*(A2)^(-1);
In prefered case
M3:=(M2)^(-1)*M1*(M2)^(-1);
So the product of operation from matrices M1, M2 is stored into default Matrix M3 for easy viewing.
The code is.
EXPORT A1,A2,A3;
EXPORT TST()
local a1,a2,b1,b2,r1,r2;
a1:=SQRT((A1(1,1)));
a2:=SQRT((A1(2,2)));
b1:=SQRT((A1(3,3)));
b2:=SQRT((A1(4,4)));
r1:=SQRT((A1(1,1)-A1(2,2))^2+4*(A1(1,2))^2);
r2:=SQRT((A1(3,3)-A1(4,4))^2+4*(A1(3,4))^2);
local l1,l2,l3,l4;
l1:=0.5*(A1(1,1)+A1(2,2)+r1);
l2:=0.5*(A1(1,1)+A1(2,2)-r1);
l3:=0.5*(A1(3,3)+A1(4,4)+r2);
l4:=0.5*(A1(3,3)+A1(4,4)-r2);
local q1,q2,p1,p2,q3,q4;
q1:=atan((l1-A1(1,1))/A1(1,2));
q2:=atan((l3-A1(3,3))/A1(3,4));
p1:=A1(1,2)/(SQRT(A1(1,1)*A1(2,2)));
p2:=A1(3,4)/(SQRT(A1(3,3)*A1(4,4)));
local t1,t2,t3,t4;
local t1:=SQRT(l1);
local t2:=SQRT(l2);
local t3:=SQRT(l3);
local t4:=SQRT(l4);
local q3,q4;
IF(q1<0)
THEN
q3:=p1+180;
PRINT ("Rezultati su ispod");
PRINT("SxA ="+a1);
PRINT("SyA ="+a2);
PRINT("A λ1="+l1);
PRINT("A λ2="+l2);
PRINT("a (A)="+t1);
PRINT("b (A)="+t2);
PRINT("R (A)="+r1);
PRINT({"A θ="+→HMS(q3)});
PRINT("----------B----------");
PRINT("SxA ="+b1);
PRINT("SyA ="+b2);
PRINT("A λ1="+l3);
PRINT("A λ2="+l4);
PRINT("a (B)="+t3);
PRINT("b (B)="+t4);
PRINT("R (B)="+r2);
PRINT({"B θ="+→HMS(q4)});
When I write
IF(q1<0)
THEN
q3:=p1+180;
IF(q1<0)
THEN
q3:=p1+180;
IF(q2<0)
THEN
q4:=p2+180;
Compute
In prefered case
